Black 1st Gen Crv 5spd
#51
#53
Re: Black 1st Gen Crv 5spd
ive been in a hunt for those cloths eversince.. once i found a cheap pair thats legit but the owner
wants 300 for it.... then i cam across several leather but w/ scrupulous sellers so i didnt even
entertain it, it might be stolen or something... then my friend offered me his rsx leaters for 100 thats
when i jumped on it... i admit it feels weird in my civic since its tall but i did guess that itll be
a great fit for the crv, you did a great job!!!
**now im back on a hunt again, you made me itch for the cloths..LOL!
the only thing keeping me from swapping out the leather from my civic is that i use the lower carriage
on the passenger side to keep my gps and some other small stuff..
NP
LOL i was thinking about that lol
#54
***Quick Update***
I'm on Vacation and i left the pics i took in my Laptop, I'll be putting more pics and more info.
The pic below was the day before honda day. i went Saturday i couldn't make it on sunday. I had to lift it up like 1/2 inch because it was rubbing like crazy in the front and the UCA got stuck even tho i shaved it down a lil. LOL!!
Anyways i'll put more pics soon.
Anybody could help me with the wiring of the side markers? i want them to be side markers and signal lights.. i only have 2 wires from the side markers.. i know you gotta connect the possitive of the side marker to the positive of the signal light (located at the head light) and the negative from the side marker ti the positive of the corner lights.. so it's like + from the sidemarkers go to the turn signal + but the - goes to the + from the parking lights instead...
I couldn't figure it out because the turn signal had 3 cables, one black, one red with a green line and a red with gray line.. which one is the positive?
Thanks!
Thanks!
#56
#58
Ok, it may not make sense but here is how it goes, i'll try my best.
in our Headlight, there is a bulb that has 3 cables which is the top corner one that acts as corner lights and as a signal light. it has 2 red and 1 black. one red is the blinker, one red is the corner light and black is ground.
when you turn on your lights, the bulb lights up as a corner light, when you turn on your signal the same bulb blinks. if i connect the Positive from the Stanley sidemarker to the blinker and the negative from the Stanley sidemarker to the other red one witch is the corner light it will work as both and it would use the ground from the same bulb.
idk if i made it hard to understand but is an easy thing to do.
#59
#60
Nice v bro... Positive on side marker goes to green on headlight
marker n negati ve on side marker goes to red...if not switch it I just glanced at my v
#61
Love your grill with the red R and the frontlights,
they combine very well.
Seats also fabulous, wheels and stance too.
Your doing a fab job
If all goes well i will be getting a 2001 B20Z1 with bumpers mirrors and spare tire cover etc, spray painted in color.
Only downside it is full of scratches
Need to see what i can do about that on the cheap ^^.
May have a look into spraying the whole thing satin/matt black myself.
Next week i will know if i get it.
#63
#67
#68
hey did u have too run spacers with the cragars ? if not what kind are they and where did u get them ? oh and i like you ride btw just blacked out my headlights the same as yours
#70
Thanks bro! and i'm running 3mm.
#71
Thank you. in the front i am. you need to. Im running the same i was running with the Si rims.. i Think is 3 mm. but i also have the 25 mm with the bolts but i'm no using it because it pokes out the wheel way too much. :/ it feels weird tho, im getting alot of vibration while driving 40 - 60 mph, if i go faster it goes away. What could it be?
check wheel balancing again... that happened to me a lot of times... especially w/ spacers involved,
also are you using hubcentric spacers?? that might be the issue too!
good luck!
#73
too wide for the center bore..... it was hard for me then to look for a hubcentric ones, i used
the ones for lexus is250/300 and bore it out a bit more, i think 3mm..!?!? but now they have it
ready for hondas in ebay:
http://www.ebay.com/itm/ICHIBA-V1-5m...ht_3527wt_1008
direct bolt on to my V w/out using the extended lugs... i just check on my torque evertime
i hit the track/course....
#75
Not really.
