Honda CR-V & Element 2WD & 4WD Element & CR-V
2001 Honda Crv-check engine reads misfire #3 cylinder
Old 10-18-2011, 09:54 AM
jim cahoe's Avatar
Default 2001 Honda Crv-check engine reads misfire #3 cylinder
Check engine light keeps coming on. Autozone checked code and it is reading #3 cylider misfire. What can I do to fix this. Car runs fine.
Old 10-18-2011, 10:55 AM
Aliman's Avatar
Default Re: 2001 Honda Crv-check engine reads misfire #3 cylinder
If the cars running fine and youve got no problems just reset the codes. The easiest way is to leave the battery off for an hour or so and the code should get reset although im not too sure of the procedure on your car
Old 10-18-2011, 11:38 AM
decode33's Avatar
If the cel light comes on then off then on sometimes then its the wires or spark related. But if its on all the time then maybe you have burned valve.
Old 10-19-2011, 06:21 AM
fast2camciv's Avatar
your car is in dire need of a valve adjustment asap! If a valve adjustment doesnt cure the misfires, have a leak down test performed...you may have burnt valves. this is a VERY common issue in crv's (i bought my crv with the exact same problem...had an exhaust valve with a 1/4" chip missing from the side of it)
Old 10-19-2011, 10:10 AM
Chiny's Avatar
What is the code it was reading from Autozone? Sounds similar to a problem I had.
dlmeeusen
06-28-2019 09:43 PM
Eliot Tapia
05-27-2019 06:18 PM
mjones123
Honda Civic (2006 - 2015)
11-07-2017 05:52 AM
DrJBCEsq136
Honda Civic (2001 - 2005)
12-03-2014 08:18 AM
kiwirob
Acura TL, RL & ZDX
07-05-2002 10:20 AM
Quick Reply: 2001 Honda Crv-check engine reads misfire #3 cylinder
