04 honda element k24a tsx swap.
Re: 04 honda element k24a tsx swap.
They are the exact same bellhousings. Did you leave an extra alignment dowel in the transmission or block?
Oh you might be struggling with the pilot bushing if someone installed a K20 bushing, they are smaller than what is found on the K24. Pretty common to go to a K20 style flywheel and clutch on the K24A2. The bore in flywheel is same size just the bushing thickness changes.
justin-95si
12-10-2012 12:08 AM
soodominican
08-28-2009 09:05 PM
