2002-2006 Honda CRV Performance Thread
#51
Re: 2002-2006 Honda CRV Performance Thread
Left Rear suspension showing Koni adjustable, Eibach springs, SPC adjustable upper arm and Whiteline adjustable sway bar link
Neuspeed 35.20.75P installed on '05 CRV SE[/QUOTE]
MMMMM...looks awesome, must make it ride so much tighter. Thanks for the tip on the adjustable rear whiteline endlinks. So so close on mine to being done, but going to opposite direction 40mm. Did you do the work on the front cartridges? Changing them over doesn't sound fun looking at the video/procedure.
#52
KINgJ8, sorry i just saw your comment after 1.5 months. Thanks, yes the ride is tight and fun, yet surprisingly comfortable. All and all I am very happy with the outcome. I chickened out on the cartridges, and had the entire work done by a nice shop in the bay area. It sounds like you are lifting, but one more thing I learned was the Eibach coil spring set does not come with rubber coil tubing for the lower seats on the struts. I have been dealing with some creaking, so next i will have to remove the coil springs and glue the new rubber tubes i bought from Eibach separately - hope the creaking will go away. It will be nice to see pictures of your suspension project
#53
Any more details on how yours functions...
Does the ECU need to be modified or is the K Pro a OBD2 plug in?
Thanks
#54
Hi all - Question on tire size and rims for 2005 CR-V:
I am considering changing rims from factory 16 x 6.5 to 17 x 7.5 or 8 with 45mm offset. I am hoping to use 235/55 17 tires. Running some calculations on Wheel-size.com it looks like tire will be sticking out 18mm from factory.
Has anyone run 235/55 on 7.5 or 8 inch wide rims with 45mm offset? Or anything close to it? Will appreciate any inputs. I don't want to roll fenders etc.
Car is dropped 1.5" front and 1" rear and has ~50mm wheelwell clearance still.
#56
Howdy folks! I am a complete Honda Newb... I have a 2003 CR-V EX automatic with the stock K24A1 engine. I would like to change the automatic out for a manual, but have no idea as to interchanges for something this new. Can anyone point me in the right direction to find a transmission, shifter, hydraulics, peddles and whatever else I need??? None of the salvage yards within 150+ miles from me have a manual 2002-2006 CR-V, much less a 2003.
Drag
Central Texas
Drag
Central Texas
#57
Drag
Central Texas
Drag
Central Texas
#59
That brushguard is beautiful! I haven't found anything like that in weeks of searching. Do you have a brand name I could go looking for? I want something more than just a bull bar.
#60
My 2005 CR-V.... I have been out of the Honda scene for 15 years or so now. Also I have relocated from the USA to Panama and slammed ricey cars like I love are not well suited for Central America so I went with this CR-V. What kinds of engine swaps can I put in this?. Back in the day I was swapping all kinds of B series and H series engines and also one K series into civics and preludes. I see some of the newer CR-V's have "Vtec Turbo" badges... Can I drop one of those in here? Hate to be such a noob. Also in the next few months I am selling my STI swapped bugeye and I think for sure I am going to get a lift kit for the CR-V soon as it sells. I will probably post updates in here for the 3 or so fans of this chassis of Honda that might check this thread :D (Also I am just waiting on the shop to order the paint and I am going to paint the front and rear bumpers)
PS: If anyone knows where I can buy the headlights in the same style I have except with clear lenses... please let me know!!
My bugeye that I will be insanely sad to see go.... however it's not doing me any good sitting in storage in Murica...
#61
#62
You can get these switch panels that fit perfectly in the center console storage on Amazon. It appears they have a newer model as well (which I just ordered) I will post a link for it also.
#63
I ordered a set of Dobinson Springs for mine. On the website they say out of stock, but if you contact them you can still purchase them and get your name on backorder. It could take up to a year, but I'm in no real rush and its the best kit offered for the second gen in my opinion. Have a couple buddies that went the spacer route, and it tends to make the ride a bit more jank because you're raising the body while keeping the stock suspension travel and spring rate. Its good for looks, and if time is an issue then its good (if that's what you're going for), but not the best in terms of functionality. Bigger stiffer springs are the way to go if you want to do it right, and the dobinson springs allow you to keep the OEM struts. Either way, order the adjustable rear upper control arms. I found a good set on amazon, $40 for the pair, and I'd recommend installing them regardless of lift. Its essential for good alignment because the stock ones, being fixed in their length, can cause the rear wheels to never be aligned properly and therefore cause unnecessary tire wear. Got my car aligned and the tires still wore in the same places, installed the adjustable ones, got it realigned, and have never had an issue since. It's different depending on the car, and in some cases the stock ones are fine but if you're lifting it, its a necessity. Also, anything over 1.50 - 2.0 in of lift, and you will need an engine/transmission drop kit to retain proper axle angle... otherwise, the splines on the end will wear out prematurely and cause problems. Hope this helps
#65
Anyone know how they went about trying to rewire the headlights and turn signals from 02-04 to 05-06 headlights? Anyone have a wire diagram or how to posted? Thanks!
#66
Hey man, that CRV looks awesome first off!! I have been looking for a brush guard like that and I was wondering where you were able to find that one? Also the brand on it? Thank you!!!
peacekpr
19
09-30-2010 11:27 AM
