*Official H/T OFFROAD/LIFTED CR-V thread!*
#3001
Re: *Official H/T OFFROAD/LIFTED CR-V thread!*
Hey guys I have a 2001 Honda CR-V.
I have it on OME springs and bilstein shocks with 3” strut spacers. The rides kinda of stiff and I was wondering if anyone would have a solid solution for me. I changed my tie rods and rear trailing arm bushings because they were bad and I thought that was the problem but it still proceeds and I also looked at bushings in my rear upper and lower and front upper and lower control arms and everything looks good but I’m not sure if I need to upgrade certain things or what to make the ride smooth again.
#3002
#3003
So I finally installed my new wheels and tires. I also got 4 led cube lights for the front and back, just have to get them wired. I think I am gonna end up getting a 1.25 inch lift spacer for the rear since I noticed it rubs slightly under load. Does anyone have recommendations? What else would I need for alignment?
I ended up getting hub centric rings, but now i cant insert the hub cover that came with the wheels...
#3004
-Intl Steve Krew
3" strut spacers, remove those.
The springs are designed to have a load on them, plus if they're brand new, they need to break in.
#3005
#3006
Alrighty boys, question.
So I hope I'm not the only one with this issue, but sunroof open+ roof rack= lots of wind and noisee.
i was thinking about getting a sunroof wind deflector, do y'all think that would cut the wind being blown into the cabin and reduce the turbulence?
#3007
-Intl Steve Krew
Yes it does. I have the oem Honda one, it works well.
Also so cracking the back windows helps to alleviate the wind buffeting.
#3008
AEROGENICS 1in spacers for sale.
Used for little less than a year. Have the nuts for them also just have to find them
200 shipped to your front door or OBO
#3009
So I finally got around to installing my 1" lift up front. Had the front end suspension apart to replace control arms, end links, ball joints, and outer tie rod ends, so I figured why not. Now I'm getting a rubber to metal squeal whenever I turn, from the right strut. That and the rears have been creaky whenever I go over bumps, since I installed them months ago. Anyone else experience this? All the struts still seem to be in good working condition. Is there a simple remedy? Something I did wrong perhaps? I'm gonna have the front end apart again soon to do the bearings since I still can't seem to get rid of the highway shake at 55-80mph, so if I can fix it then, I'd like to.
#3010
#3011
I also have a shake on the highway. Can't seem to get rid of it. I have balanced wheels, it has brand new tires I have even checked each one for belt separation, wheel centric rings, done multiple steering component checks, even alignment a few times. (I'm a Journeyman mechanic, and have a shop) I also have the shake on acceleration, so I am thinking I might change out the CV axles running out of things to replace.
#3012
this guys sells custom spacers, seems like a decent budget option https://www.hondarescue.com/shop
#3013
Anyone on here try out the Honda rescue subframe drop kit to get rid of the cv axle shake on acceleration?
#3014
Those that have exterior lights on there CRV. Where and how are you running the wires into the cabin? I wanted to put rock lights in the wheel wells and spot lights but cant seem to figure out how to run them into the cabin for a switch?
#3015
My 98’ I bought for $525.00 and I’m slowly trying to fix little problems and make it a little better .
I have it on 15x7 Black Rhino Boxers with 215/75 BF Goodrich Ko2’s . Just recently put Aerogenics 1.5” lift spacers in the rear . Thinking now I need to bring the front up a little.
#3016
-Intl Steve Krew
Those wheels look clean! What offset?
I love the look of a slightly lower offset yet not the -15 or 0 jeep type wheels that stick out like 3 inches on a Honda...
#3017
The offset is +15mm and thank you . I wanted something different with the wheels and haven’t seen them on a crv and thought why not ?
#3019
Been running like this for 1½ years now without any problems
#3021
I'm thinking I might need another battery. I'm doing a 6 gang rocker panel. I'm going to be running a sub, 2 light bars, light pods, and fog lights.
Then for the 6th one I want to do a power switch that cuts all power to the accessories.
So do y'all think it would be nessasary for another battery, if so where would I put it? (05 crv)
Then any ideas on that power switch?
#3022
I run
* Light bar 100w (real wattage, not chinese numbers)
* 4x 60w (same here, real numbers)
* 2x Foglights (51w each)
* 2x small lights (55w each)
* 4x rock lights (9w each)
* Pioneer TS-WX11A underseat sub with 150w amp
* 6 rocker switch panel
* 3 external gauges
* CB Radio
And I´m running on a 74Ah battery with stock alternator without any problems.
#3024
I failed to find any "easy" way to pull cables into the cabin except for drilling through the torpedo wall, which I was not very keen on, so I pulled the cables behind the wheel arch and through the side plate in the doorway.
