Orbis AWD Hybrid Conversion for FK8
Highlights:
- No drivetrain, differential, axles, or other modifications needed
- Batteries are charged by braking
- Each wheel adds +50WHP
- Wheels+Hub+Brake+Rotor weigh very similar to OEM weights
- Batteries and full kit add 175lb to the car
- Weight split moves to 57/43 from added weight (more weight in rear)
- Kit includes computer that work with factory ECU. No tuning needed.
- Cost starting at $10K sans batteries, so $12-$13K estimated total.
- Motors and gears are completely weatherproof
- MPG and emissions are improved
- CARB legal
- 0-60 time is lowered by 0.6 seconds (claimed)
Honestly, I want to wait for more information to come out and for this to get out of the "pre order" phase, but this is probably the best modification I've ever seen available for a Honda. I'm curious to see how the electric motors withstand prolong runs and heat, and hear some owner experiences once some others take the plunge.
I also see no reason why this kit couldn't be used in conjunction with a turbo upgrade, like the one offered by Full-Race. In theory, the FK8 could easily achieve supercar performance status with the AWD hybrid kit used in conjunction with upgraded turbo.
-Intl Steve Krew
Re: Orbis AWD Hybrid Conversion for FK8
MPG/emissions improved? MPG improved, maybe, but car is still polluting the same amount.
CARB legal
I wonder how well those wheels handle potholes because that is going to ruin someone's day/motor if the wheel bends and seizes the motor.
If you're buying a CTR for 35k and then adding another 13k on top of that, plus the turbo kit upgrade (~6k depending on options) you're looking at 55-60k depending on who's doing the work.
That's a lot of money for an econobox
CARB legal
-Intl Steve Krew
Ok so you buy a refurb'd battery pack out of a Prius...
How does it charge? The Prius system uses the motor as a generator and charges the hybrid battery. No mention of charging.
7-13% regen is meh. So instead of 40 miles EV range you'll get about 44 EV range.
No battery monitor to tell you if you have capacity or not.
Let's say you don't run it on EV only (I doubt that's possible to run the CTR in an EV only mode but who knows) you'll probably end up with 80 miles of 'fun' and then you're back to your boring old CTR with a passenger in the back. I wonder if it is possible to 'turn off' the motor power and allow it to recharge the battery as you drive around.
Even if looking at MSRP, $60K all in for what could (theoretically) be a 2019 5 door with supercar tier performance is not a terrible deal. I agree the price is steep, but I definitely see this appealing to some people, especially once we start seeing more FK8's on the used market for lower prices.
I agree with your concerns about the wheels handling shock and hard drops/bangs - Like I said, I want to see more actual usage of this before deciding it's all it's chalked up to be. So far it seems relatively promising though.
Anyway, lots still to question, but I am most definitely intrigued.
footwork mastery
This is such old news. Why not read the tons of info on them? Would never waste money on that garbage, if they gave me the whole kit for free I wouldn’t use it.
If you’re worried about 0-60 times buy a golf r DSG. CTR is meant to be road raced not drag raced your just adding unneeded weight.
footwork mastery
PS, if you’re that worried about 0-60 get Hondata and run their tune with traction control. Likely knocks off about the same .5-.6 seconds and doesn’t hurt the cars performance/ look like doo doo
It's several months old, but no one on these forums have discussed it yet. I wanted to see what the interest level was (apparently, very low).
Anyway, I still think this is pretty amazing. And I also don't think this is "drag only" or only useful for a 0-60 time. I'm concerned about the noise level of the rollers, as well as their longevity through daily driving or punishing track time, which is why I'm waiting to see what comes in the future.
Haha this thing came into the dealership I work at, came in and left on a trailer. Weird wheel/hub thing intact but no rear brakes or any of the electric stuff present
footwork mastery
The price range is very big. For half the money it would be a good deal. For stock power its useless. This kit might be a good choice for someone that will target 500hp+
Buying a Golf R if you know what you are doing in not an option either.
