zc vtec
Re: zc vtec (dasistheone)
isnt a zc motor a dohc d16 non vtec?
Puts about the same power as the sohc vtec... but it isnt vtec... however its dohc
Ive seen jdm tegs with them... some tegs in japan have a 1600 dohc non vtec motor putting down near 130hp. This is in body styles 94- 2000 in jap.
Over here I think they came in the older gen integras like prior to 90
Im not sure how the years go for that gen integra... but its the model with the flip headlights
correct if im wrong...
Re: zc vtec (RED BADGE)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RED BADGE »</TD></TR><TR><TD CLASS="quote">isnt a zc motor a dohc d16 non vtec?
i dont think "zc vtec" is the correct term</TD></TR></TABLE>
they are not vtec but i am almost sure there is a vtec swap available
Re: zc vtec (civictildeath)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civictildeath »</TD></TR><TR><TD CLASS="quote">they are not vtec but i am almost sure there is a vtec swap available</TD></TR></TABLE>
cool
I guess the only option would be a sohc vtec head on the zc block.
zc pistons with a sohc head would yield a very high compression ratio... how ever the bore/stroke on the zc block is the same as the sohc vtec....
hence really its only the zc pistons that would gain u power from a combo like that
cool
actually a d16y8 has 2hp less but 1 ftlbs tq more than the dohc zc does
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RED BADGE »</TD></TR><TR><TD CLASS="quote">I guess the only option would be a sohc vtec head on the zc block.
with the zc piston the compression is bumped quite a bit.
i seriously dont think the sohc head will bolt up to the block but a zc head was put on a d15 block before https://honda-tech.com/zerothread?id=1079426
Re: (Traymack1)
its not the same as a d16z6 it pulls way harder i have a d16z6 in my crx and my zc sohc vtec in my cx hatch will beat its with ease
TrueUntilDeath.com
10-29-2006 09:32 AM
