zc swap
zc swap
i have a obd0 zc swap layin in my garage havent put it in anything yet was just sitting on it waiting for an oppertune moment to do something with it. well my single ******* is finally givin up and dont wanna fix it so i was curious what exactly i would need to put it in my 95 ex coupe? i know i cant use the dizzy cause of the harness change so do i spend almost 200 on a dizzy for it or is there one i can swap internals into the stock dizzy or any that will just plug and play?
Seagull Management
Re: zc swap
You need an OBD1 DOHC ZC distributor and OBD1 injectors. I actually have a distributor (has a brand new bearing in it too) and an OBD1 DOHC ZC intake manifold, if you're interested PM me.
Seagull Management
Re: zc swap
PM me for details and a price.
For most of it you should actually be able to use the OBD0 stuff, Z6 stuff will also work, manifold itself has to be ZC, but OBD0 should work.
Z6 are the same, actually so are D15B7, its only D15B8/D15Z1 and D16Y7 that use 190cc injectors, the rest of the D-series engines and all B-series are 240cc.
