ZC SOHC VTEC 1.6L 140HP is this for real?
Old 06-07-2005, 01:18 PM
CivicHP's Avatar
Default ZC SOHC VTEC 1.6L 140HP is this for real?
i cam across a guy on ebay who had this for sale a ZC SOHC VTEC http://cgi.ebay.com/ebaymotors...47099
i email him and said that you must had made an error cause there was never a zc vtec and less a sohc but he insisted that it was real and it was produced in japan delsol 92-95. i still did not believe him cause i never heard of that engine. i did a search and found it on an engine import site here are the specs prety good if you ask me for a single cam motor that has to be the fastes single cam motor nice specs
Manufacturer: Honda
Model: Civic / Del Sol
Mileage: 25000 -45000
Horsepower: 140 HP
Description: Honda Civic / Del Sol 92 - 95 Sohc Vtec 1.6 L ( Engine, Transmission Manual & ECU )
Part#: ZC SOHC VTEC
they also have the comon one we all know D15B so it can't be a mistake. judging by the specs it look like it a D15B or D16Z6 head slapped on a zc block or a D1B5 block with zc pistons.what you guys think?
CivicHP is offline
Old 06-07-2005, 01:26 PM
alleyezonme's Avatar
Default Re: ZC SOHC VTEC 1.6L 140HP is this for real? (CivicHP)
I thought the zc was an obd0 engine DOHC no vtec.
alleyezonme is offline
Old 06-07-2005, 01:27 PM
turboxsi's Avatar
i know the sohc Vtec del sol si came with the d16z6. I don't beleive that ebay item is correct. As the dohc ZC (non-vtec 1.6) has 140, but i have not seen that motor described in the ebay post. But the pic looks like a d16z6 or d15 motor.
turboxsi is offline
Old 06-07-2005, 01:29 PM
egsleepercivic's Avatar
I believe the zc 1.6 vtec is the JDM version of the d16z6, someone correct me if I am wrong
egsleepercivic is offline
Old 06-07-2005, 01:42 PM
b16a2rida's Avatar
http://clubcivic.com/board/engine-codes.php
b16a2rida is offline
familyhauler's Avatar
Never heard of that one, but i do know there is 2 ZC motors. A single cam non Vtec that only puts out 120hp and a dohc non Vtec that puts out 130hp, you might be right on this one he might have mated the d15b head to the sohc zc block, and it would make a couple extra horses because the d15b uses a vx 1.5 bottom end lil bit lower compression than 1.6 and naturally less torque but due soley to the head it gets more hp and torque than the usdm 1.6 Vtec, so mini-me d15b head to a 1.6zc bottom end=jdm ZC Vtec i guess
familyhauler is offline
Old 06-07-2005, 01:45 PM
EJ1 wilcox's Avatar
Default Re: ZC SOHC VTEC 1.6L 140HP is this for real? (familyhauler)
I have seen those engines on eBay from time to time... I always just assumed that it was an error of some sort...
EJ1 wilcox is offline
Old 06-07-2005, 03:13 PM
d16singlecammer's Avatar
Default Re: ZC SOHC VTEC 1.6L 140HP is this for real? (EJ1 wilcox)
There is a SOHC Vtec ZC, identical to the D16Z6. And no that is not a OBD0 sohc ZC with a vtec head. Im looking into buying a sohc vtec ZC engine, I see different horsepower outputs out this engine. I want to get a positive answer wheter this engine pumps 130 or 140? Also is it only a myth about it having the D15B cam?
d16singlecammer is offline
Old 06-07-2005, 03:17 PM
DJ_SaNdOz's Avatar
Default Re: ZC SOHC VTEC 1.6L 140HP is this for real? (d15singlecammer)
There is the brown top DOHC OBD0 ZC, a Black Top OBD0 DOHC ZC, a SOHC OBD0 ZC (same as D16A6), and OBD1 Black Top DOHC ZC, and a SOHC VTEC ZC (same asZ6).
DJ_SaNdOz is offline
Old 10-29-2006, 09:29 AM
dubzxallxstar's Avatar
Default Re: ZC SOHC VTEC 1.6L 140HP is this for real? (DJ_SaNdOz)
i have the zc sohc vtec i replace it with my d16z6......the zc vtec has a black valve cover thats says vtec......everytime i work on my car i just order parts for the d16z6 and part fits without a hitch....
dubzxallxstar is offline
Old 06-06-2013, 01:20 PM
GordoJqrLancer's Avatar
I have a zc 1.6 vtec single cam on my civic so it does exist
GordoJqrLancer is offline
Old 06-06-2013, 01:23 PM
B_Swapped93's Avatar
8 years later.....^
B_Swapped93 is offline
Old 06-06-2013, 05:22 PM
MikesEJ1's Avatar
Originally Posted by B_Swapped93
8 years later.....^
lol
MikesEJ1 is offline
Old 06-07-2013, 04:59 AM
sleepyaccord96's Avatar
i always wonder why the ZC did not have a normal engine code like all other honda engines... weird. Besides that i cannot fathom a d series sohc engine pumping out 140 from the factory... from what i have read the zc sohc vtec engine has 130
sleepyaccord96 is offline
Old 06-07-2013, 05:25 AM
If you loved me, you'd all sell me your magic cards to me today
doctorake's Avatar
8 years later.....^
7 years you mean
doctorake is offline
Old 06-07-2013, 05:55 AM
The Grumpiest
grumblemarc's Avatar
5+8=13
As of today any way.
grumblemarc is offline
Old 06-07-2013, 06:02 AM
JuggerNaut-CTR's Avatar
2006 + 7 = 2013
Right?
JuggerNaut-CTR is offline
Old 06-07-2013, 06:08 AM
doctorake's Avatar
was going with the "10-29-2006" not the thread creation date.
Apples and oranges, mods gonna lock it hopefully.
Old 06-07-2013, 06:20 AM
The Grumpiest
Oh. You went by the day the thread died. Gotcha.
civicboy420
10
08-29-2011 12:14 PM
2 Loe 4 Fat Hoes
05-28-2005 11:41 AM
finestpinoy
07-22-2004 09:06 PM
94eg4
02-06-2004 07:32 AM
crx88fast
17
08-07-2003 04:53 PM
Quick Reply: ZC SOHC VTEC 1.6L 140HP is this for real?
