zc sohc block and a d16z6 head will it work ?
I've got a 94 civic ex and my bros got an 88 crx with a zc sohc swap. I'm wondering if by using the bottom end of that engine and my d16z6 head will work in my civic .
Re: zc sohc block and a d16z6 head will it work ? (autotech94)
if the bolt patter on the zc is the same as the d16a6 (from the old ass TEG'S) then no it has a different bolt pattern. but i am not sure as to the bolt pattern for the zc block. but i would think since these two engines are essentially the same then no it wont work. i know the a6 wont work cause we tried to put that head on a a1 block making a dohc crx si engine w/o having to locate a zc when those heads are a dime a dozen in my local junkyard. maybe someone on here will be able to tell you if the pattern is the same, but im guessing no.
Re: zc sohc block and a d16z6 head will it work ? (VTECschmetec)
the zc engine is basically the same as an 88-91 si d16 but with higher compression and bigger valves.
yes, but i think the headbolts dont line up. they might, but the d16a6 is the same platform as the zc and i know the headbolts on the A6 dont line up with the A1 (i might have these numbers confused it is kinda late here in spain and im kinda drowsey) but im sure someone on here has gotta know https://honda-tech.com/forums/images/smilies/emthup.gif
if your talking about a sohc ZC block and mating it with a 92-95 Sohc Vtec head "YES" it will work because i did this once and only one time for a requested customer the headbolts line up and everything just use your hydraulic parts for the tranny and dont forget to pull out the oil jet on the ZC block
It will work. My cousin has that setup and feels pretty good when I road in it. https://honda-tech.com/forums/images/smilies/emthup.gif
Re: zc sohc block and a d16z6 head will it work ? (dramatic_scientist)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dramatic_scientist »</TD></TR><TR><TD CLASS="quote">if your talking about a sohc ZC block and mating it with a 92-95 Sohc Vtec head "YES" it will work because i did this once and only one time for a requested customer the headbolts line up and everything just use your hydraulic parts for the tranny and dont forget to pull out the oil jet on the ZC block</TD></TR></TABLE>
what about the DOHC ZC block? |
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VTECschmetec »</TD></TR><TR><TD CLASS="quote">
what about the DOHC ZC block?</TD></TR></TABLE> The keyword is SOHC. https://honda-tech.com/forums/images...es/emsmile.gif |
Re: zc sohc block and a d16z6 head will it work ? (BoOs7eDSoHc)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BoOs7eDSoHc »</TD></TR><TR><TD CLASS="quote">
The keyword is SOHC. https://honda-tech.com/forums/images...es/emsmile.gif </TD></TR></TABLE> as in? u do know the zc is a D-SERIES block, right? |
as in? u do know the zc is a D-SERIES block, right?</TD></TR></TABLE> Obviously not. And didn't somebody at one point mate a DOHC head to an SOHC block? I thought I had seen that somewhere. |
Re: zc sohc block and a d16z6 head will it work ? (JRI94)
i dunno that is what i was asking. i know what i was gonna try wouldnt work, but i didnt know if the zc and the old teg with the d16 DOHC had the same head bolt pattern
as in? u do know the zc is a D-SERIES block, right?</TD></TR></TABLE> I know that there is a sohc and a dohc zc. I might've gotten it mixed up with b-series. But then since it's a dohc I thought the bolt patterns would be different. http://images.honda-tech.com/set1//smile/emcrook.gif |
if the ZC is a SOHC block then of course it will work.
if the ZC is a DOHC block then NOPE, the D16Z6 sohc head will not work... *if it did then you'd see us all swapping dohc ZC heads onto our sohc shortblocks! |
oil jet?
Re: zc sohc block and a d16z6 head will it work ? (owen_the_soyboy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by owen_the_soyboy »</TD></TR><TR><TD CLASS="quote">if the ZC is a SOHC block then of course it will work.
if the ZC is a DOHC block then NOPE, the D16Z6 sohc head will not work... *if it did then you'd see us all swapping dohc ZC heads onto our sohc shortblocks! </TD></TR></TABLE> I was just going to say the exact same thing. https://honda-tech.com/forums/images/smilies/emthup.gif |
Originally Posted by TurboEH2
(Post 10850593)
https://cimg9.ibsrv.net/gimg/honda-t...c1b6ace60.jpeg https://cimg1.ibsrv.net/gimg/honda-t...6f7f7612e.jpeg https://cimg2.ibsrv.net/gimg/honda-t...f6b254149.jpeg https://cimg3.ibsrv.net/gimg/honda-t...bd1a88dcc.jpeg https://cimg4.ibsrv.net/gimg/honda-t...e2c68512d.jpeg |
