ZC long block questions
Will a Zc DOHC Long block swap right in to my 94 civic that had a d16z6. cause i found one for a thousand bucks. comes with tranny and ecu but no wiring harness.
if it doesnt swap right in. where can i find the wiring harness and or motor mounts if it needs motor mounts
Thanks
zac
Thanks
zac
Seagull Management
Re: ZC long block questions
If its the OBD1 version it drops right in (make sure it has the OBD1 distributor as they are very hard to find, no USDM civic or integra uses that distributor) If its the OBD0 version its probably best to stay away (it will still bolt up, but you will have to deal with several things from an electrical point of view) beware the the ZC wont pass emissions in several states.
EJ1_samson
11-14-2009 08:33 AM
civic_hatch
06-22-2006 08:51 PM
