z6 crank in a y8 block??
read my fair share of stories with d16y cranks spinning rod bearings. can a z6 crank be used in a y series block? i'd have no problem using the z6 rods either if need be
Re: z6 crank in a y8 block?? (blackeg)
use the search function, thats why you havent got any responses, all you need to do is search around a bit and you should find all the info you need
the reason they spin bearings is the oil pump, not the crank. Y series oil pumps suck in realtion to any other D series oil pump. If you put the z6 crank in youll loose yur dipstick. If your that worried about either get a Toga pump and shim it, port and shim your stock pump or send your pump out to Endyn to have them modify it for you
I am bringing this back from the dead for the sole reason that the above statement is wrong. the Y series cranks have crappy oiling ports that dont even measure up to how good the Z6 crank is.
So can they be swapped?
yes, u can put a z6 crank into a y8 i hear
my crankshaft pulley came out and ate up my keyway walls, so i need to replace my crank cause the keyway is just too bad to repair.
someone told me to put a z6 into my y8 also but im wondering if theres anything else i need to swap aswell.
right now m ycar is unusable till i fix this cause everytime i start it up now it knocks like its ticcking, i dunno if this is because of spun rod bearings?
i wouldnt be concerned if it was just the pully and keyway but i dont knowwhat thehell the ticking is
Well I dont really wanna hear "what i hear" lol no offense cause I dont wanna throw it in and then BAM throw a rod or something. Its one of those things that i HAVE to know pretty much. I dont want a ticking time bomb 10 miles down the road if you knwo what I mean. If i HAD 1K to just drop in it then I would mess around with that as I wouldnt care to replace bearings lol but i dont
http://d-series.org/forums/engine-bu...fferences.html
This proves they are the same, CEPT FOR THE OILING PORTS and that they will work.
i have a bent z6 crank and need a crank to finish my motor.
now i know i can use a y7 crank, which i have access to for free, unless its bent too, somebody did a mini me and left a head bolt out, needless to say the cylinders filled with coolant and oil and hydrolocked)
ive also heard that the only difference in d16 cranks from 88-91 is that the d16a6 and early d16z6 cranks had 2 oiling holes in places that the later z6 and y series cranks have only one hole. even if that is 100% true the main culprit still seems to be that damn oil pump...
although i never hear complaints of low oil psi out of the y engines just that they spin bearings. ive spun bearings twice, one being a stock y7 that i ran low on oil... but my lsvtec did the same thing on low oil. user error? possibly.
Probably user error there with your low oil problem haha.
bnmm
08-01-2011 12:31 PM
slob20ef
09-30-2009 10:12 AM
block, cam, crank, crankshaft, crankshafts, d16y, difference, fit, interchangable, pulleys, put, series, single, y8, z6
