Yellow dirty looking Hadlights
Old 07-19-2003, 05:51 PM
jlamaster's Avatar
Default Yellow dirty looking Hadlights
I know this is probally not in the right fourm but i can't post in the cosmetic fourm. Anyways i've got a 96 civic and the headlights are faded and dirty on the inside anyone know what would clean them.
Old 07-19-2003, 05:58 PM
viprcr1's Avatar
Default Re: Yellow dirty looking Hadlights (jlamaster)
try a search. there was a post on this a while back.
i recommend maybe simply green, that cleans just about anything.
Old 07-19-2003, 06:38 PM
X2BOARD's Avatar
Default Re: Yellow dirty looking Hadlights (viprcr1)
ANY autoparts store, you can find this and it works.
BLUE MAGIC (some paste in a jar)
I think you will find it where you find the rim cleaner. Just rub it on the headlamps with a soft cloth and wipe clean. It'll bring it back to life, crystal clear.
Old 07-19-2003, 06:44 PM
SprayinCX's Avatar
Default Re: Yellow dirty looking Hadlights (X2BOARD)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by X2BOARD &raquo;</TD></TR><TR><TD CLASS="quote">ANY autoparts store, you can find this and it works.
I think you will find it where you find the rim cleaner. Just rub it on the headlamps with a soft cloth and wipe clean. It'll bring it back to life, crystal clear.</TD></TR></TABLE>
i have never heard of this magical stuff you talk about maybe i will try this BlUe MaGiC that you are raving about
Old 07-20-2003, 12:40 AM
built562's Avatar
Default Re: Yellow dirty looking Hadlights (SprayinCX)
are you sure its on the inside of the lights? then nothing that people suggest will work.
but here is the real trick. it works for any car with plastic headlights, and can be done on side markers and corners.
a 2000 grit wet sand and a buff, they come out clean as hell, i just did 2 cars last week.
remove the headlights from the car and place a few sheets of 200 grit sand paper in a bucket of soapy water (car wash and water) let it soak for at least 15 minutes. wet the headlights then begin to sand, remeber to re-dip the sand paper every few strokes, the more you do it the better they will come out.
i say sand for at least 30 minutes. then rinse with cool clean water.
the lights might still look a little cloudy.
now spread some wax on the lights with a rag. any kind will do, i use meguirs scratch x or car polish. let it haze up like waxing a car. then buff the hell out of it with a high speed buffer.
brand new lights!!!
Old 07-20-2003, 11:01 AM
sohcvtec1995's Avatar
Default Re: Yellow dirty looking Hadlights (akumaracer)
i HAD A 97 EX WITH THE SAME PROBLEM. I USED NAIL POLISSH REMOVER. tHE YELLOW STUFF IS A CLEAR FILM THAT IS ON THE HEADLIGHTS THAT THE SUN EATS AWAY. SO JUST USE SOME NAIL POLISH REMOVER AND SOME WINDEX AND IT SHOULD COME RIGHT OFF.
Old 07-20-2003, 11:08 AM
jamesr's Avatar
i heard on here that you could use simple green and vinegar. anyway i tried it and it didnt work, ill have to try the sandpaper gig. thanx
4doorEF
02-20-2008 10:12 AM
h22_crx
02-19-2007 07:41 AM
Quick Reply: Yellow dirty looking Hadlights
