which year eg hatch si has abs?
i need to buy new brakes but i dont know if my 92 hatch si has abs or not. it doesnt say it anywhere so i would assume it doesnt right?
ANY car with ABS should have a dash cluster mounted warning light that lights up when you first start your car. i'm pretty sure no hatches ever had abs, and it was only optional on ex's
Risky Business
Re: (blykins)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blykins »</TD></TR><TR><TD CLASS="quote">94, 95 Si's have 4wheel disc+ABS.</TD></TR></TABLE>
I thought it was optional?
Re: (blykins)
i thought that was just optional.
Re: (BauleyCivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BauleyCivic »</TD></TR><TR><TD CLASS="quote">
I thought it was optional?</TD></TR></TABLE>
it was... my friends 95 si has 4 wheel disc brakes but no abs
Re: which year eg hatch si has abs? (auburnBoy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by auburnBoy »</TD></TR><TR><TD CLASS="quote">i need to buy new brakes but i dont know if my 92 hatch si has abs or not. it doesnt say it anywhere so i would assume it doesnt right?</TD></TR></TABLE>
These orange wire harness pieces near my chrome air intake are a sure way to determine that your eg has ABS.
Re: (snatch13)
it is a option as it was with the ex coupe and sedan. Abs only came standard on integras. Also another way you can tell if the car has abs is by looking under the hood, by the airbox, there will be a abs module with brake lines going into it. Also you can just check and see if there is a abs fuse.
Re: (jpb105079)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jpb105079 »</TD></TR><TR><TD CLASS="quote">what year did the integra come with abs as a standard cause i was gonna get a rear integra disk brakes but my eg doesnt have abs</TD></TR></TABLE>
you can put any integra rear disc setup on your car regardless of whether the integra had or did not have ABS.
Re: (dampachi)
My 93 Si has 4 disc brakes and ABS. I have never seen the orange wire harness pieces in that spot. Would be hard to miss in my aztec pearl green engine bay. Is there any other place it could be? Maybe they are just different colored. I'll check it out tomorrow... or later today I guess.
Re: (crashN2u)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crashN2u »</TD></TR><TR><TD CLASS="quote">My 93 Si has 4 disc brakes and ABS. I have never seen the orange wire harness pieces in that spot. Would be hard to miss in my aztec pearl green engine bay. Is there any other place it could be? Maybe they are just different colored. I'll check it out tomorrow... or later today I guess.</TD></TR></TABLE>you prob just don't have abs lol...........you have a brake booster which goes to your master cylinder and from the MC there should be some short brake lines to the abs hydraulic unit, it looks like a big billet block of aluminum. If it does'nt have that it doesnt have abs................John
Re: (blykins)
option, 95si w/o abs here
official honda whore
Re: (Sp00n'd Supra)
actually the only si's with abs i have ever seen were 94's, i have never seen a 95 si with abs, and right now i currently own 2 ex's with abs i just love having the same size breaks as a gsr
Solbros Owns Me
Re: (coptzer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by coptzer »</TD></TR><TR><TD CLASS="quote">actually the only si's with abs i have ever seen were 94's, i have never seen a 95 si with abs, and right now i currently own 2 ex's with abs i just love having the same size breaks as a gsr </TD></TR></TABLE>
I've only heard of 94 Si's having optional ABS....Tom will know for sure
Re:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sp00n’d Supra »</TD></TR><TR><TD CLASS="quote">
95si w/o abs here</TD></TR></TABLE>
Ditto.
Ditto.
Re: (Jimmy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jimmy »</TD></TR><TR><TD CLASS="quote">Whats the differences in when you buy pads and rotors for a car with and without abs?</TD></TR></TABLE>
abs equipped cars have larger brakes, so they use diff rotors and pads, except rear is the same reguardless of abs
well the best thing to do is look at ur hub assembly and see if u have a line runing that looks like its connected to the arm that extends from the up to the suspension with a castle nut on it and if u look in ur engine bay u will see a pile of **** on the passengers side clutter mess of cylinder looking like things. with clips that connect to eachother and not the engine harness may be differnt colored like on the del sol vtec they are orange.
