y8 power output
Re: y8 power output (Eaglekper0046)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eaglekper0046 »</TD></TR><TR><TD CLASS="quote">Whats the hp output for the y8 motor? I have a y7 with y8 I think it should be the same</TD></TR></TABLE>
If you have a Y7 block with a Y8 head, you will have slightly more than stock. The compression ratio for a stock Y8 is around 9.5:1 while a Y7 block/Y8 head will have around 10.2:1 compression.
Brandon
Brandon
Re: y8 power output (B96v6)
that is a true statement, cause I have "minime" swap in my car and everyone else that has a regular y8 motor says that my car actually feels a lot better than theirs.
Re: y8 power output (sicones)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sicones »</TD></TR><TR><TD CLASS="quote">that dyno sheet says 110whp, a stock y8 with bolts ons put down the same measly 109-110hp</TD></TR></TABLE>
Exactally, don't let anyone tell you that a y7-y8 minime bumps the compression way up. The y7 and y8 botom ends are pretty much identical. The higher compression ratio comes into play when you do a mini-me on a d15 block.
Re: y8 power output (JayDiemB16aCivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JayDiemB16aCivic »</TD></TR><TR><TD CLASS="quote">you know what I have to say about D series
hella...........plus, a lot of the y8 motors are prone to getting rod knock........thats why i went to the DOHC side...........
Location: University of Massachusetts, Amherst, Ma, US of A
Re: y8 power output (Superdragr45)
thats how I blew up my y8, I went to 7,500 rpms and well I threw a rod and that was it! ****** weak *** motors.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JayDiemB16aCivic »</TD></TR><TR><TD CLASS="quote">thats how I blew up my y8, I went to 7,500 rpms and well I threw a rod and that was it! ****** weak *** motors.
dude why would you rev a D16y8 that high anyway dumbass
yes y8's suck ***... but the z6's are teh ****.. mine goes to 8800 no problem.. it pulls up to 8400 after that it kinda lags but i ususally shift at 8300 and no problems at all.. its been done many many times im not saying its good to over rev the **** out of ur motor and i may be dumb for doing it but i like the half a second difference in the time....
BOOST them!
BOOST them!
Re: y8 power output (siregcivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by siregcivic »</TD></TR><TR><TD CLASS="quote">yes y8's suck ***... but the z6's are teh ****.. </TD></TR></TABLE>
both suck *** unless they are boosted. Even then I would rather have an LS2 for my performance needs
I use my honda to go to work and back.
Re: y8 power output (elf_vang)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by elf_vang »</TD></TR><TR><TD CLASS="quote">
dude why would you rev a D16y8 that high anyway dumbass</TD></TR></TABLE>
ok fckhead, 200 rpms over the f*ing 7300 rpm redline, normally that won't hurt a motor, but, when we are talking about econo shitbox D series then that would pose as a problem huh. Face it, D series suck no matter what. Even if you boost em they will never compare to a B series.
D series = Junk
D series = Junk
D series = Junk </TD></TR></TABLE>
there are plenty of people making good power with d16s/d15s .. yea potenial of the d-series motors runout .. but who cares if i was looking for 400+ hp i wouldnt stay with my D but 250-300 will fit me well and hopefully put me in the 12s.. thats my goal .. then if i kill it, expletive the B ill buy a K
We didn't ask.
B
We didn't ask.
B
ok guy...whatever you say....
Ignorance is bliss.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Superdragr45 »</TD></TR><TR><TD CLASS="quote"> hella...........plus, a lot of the y8 motors are prone to getting rod knock........thats why i went to the DOHC side...........</TD></TR></TABLE>
Not if you take care of them. You think DOHC are impervious to spinning a bearing too?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JayDiemB16aCivic »</TD></TR><TR><TD CLASS="quote">ok fckhead, 200 rpms over the f*ing 7300 rpm redline, normally that won't hurt a motor, but, when we are talking about econo shitbox D series then that would pose as a problem huh. Face it, D series suck no matter what. Even if you boost em they will never compare to a B series.
Last time I sat in my car and looked at the STOCK redline it was 6,800 not 7,300. 7,300 is the fuel cut-off. In other words that's honda saying don't push your ******* engine past that.
People will always have their opinions about what engine is best, fact is, none are the best. You can think your B series is a gift from god, and I'll sit back and enjoy my 30+ mpg. If you aren't asked for you opinion then STFU.
Back on topic, the hp rating for the y8 stock is 127 to the flywheel. To the wheels, that will depend on a few things. IE, wheel and tire combo and how old the engine is. You're looking at anywhere between 100-115 to the wheels.
Ignorance is bliss.
Unceasing Measure
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JayDiemB16aCivic »</TD></TR><TR><TD CLASS="quote">ok fckhead, 200 rpms over the f*ing 7300 rpm redline, normally that won't hurt a motor, but, when we are talking about econo shitbox D series then that would pose as a problem huh. Face it, D series suck no matter what. Even if you boost em they will never compare to a B series.</TD></TR></TABLE>
You are a superior grade dumbass, aren't you? 7500rpm is past even the lofty <FONT COLOR="red">FUEL CUT</FONT> - something that should never be touched unless you've built the engine to safely deal with the consequences. If you blew up a D-series motor from spinning it too high it's your own damn fault and has nothing to do with the quality of the motor (which is very good).
And I welcome you to bring your big and bad B-series motors to a road course and tell me after three or four laps how shitty my stock D16Z6 with 262+ thousand miles is.
Re: y8 power output (Archidictus)
explain how a turbo d series pulling 200 plus hp is worse than a b16 with 160 hp? D series have plenty of potential if you know what your doing, all he asked was how much power they make, take it easy all of you "D series sucks B series Rocks" guys
Re: y8 power output (Civicse)
ok yea a stock y8 puts out a whole waaping 127 crank hp. big whoop. even after you boost it its only good for; what did edelbrock put out on their y8? like 170hp. I'm bashin d series only because I seen way too many of these motors gone to junk due to RODS. Their bottom ends suck. I was considering boosting my y8 until I ran into the problem of a rod issue. it had no problem going all the way to 7300 rpms, where the redline on my 99ex was. shifts were accurate and posed no problem till the one day I went a little too high and well the rod went first. my friend had the same problem but he didnt take it to 7500. regular driving. he since then has gone through 2 d16y8s and is now saying expletive the d series and moving onto the b series.
I don't know about all of you with the basic bolt ons to a y8, but I was being beat a lot, and to tell you the truth, it's quite embarassing. And as for fuel, well if all of you like going slow all the time and being beat by dodge neons go right ahead. But I'd rather have a pretty fast car that I'm proud of and to see the look on some peoples faces that they just lost to a 4 banger. But whatever, just telling you that the d series isn't the best of motors.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Civicse »</TD></TR><TR><TD CLASS="quote">explain how a turbo d series pulling 200 plus hp is worse than a b16 with 160 hp? D series have plenty of potential if you know what your doing, all he asked was how much power they make, take it easy all of you "D series sucks B series Rocks" guys</TD></TR></TABLE>
and this *******, a stock d16y8 makes 127 and a stock b series has 160 USDM of course. How is that d series better than the b series? Can you explain to me that one. VTEC in a d series just blows it out the dick cuz there really isn't any type of VTEC at all. Their bottom ends suck too, b series rods are a lot tougher than the d series. D series is for ECONO.
Boosted d series- 200 hp give or take, I'm giving in this part of this discussion
Boosted b sereis - 250 hp. maybe a little less or more, depending on what you do of course.
can you tell me how the d series is gonna be better than the b series. Can you explain to me why so many people have blown up a d series after throwing a turbo on it cuz the d series motors are so fragile.
1.The b series rods are a lot tougher than the ones found on the d series
2. You have a more distinct VTEC. b18c1's and 5's are totally ******* nasty.
3. A stock B series has about the same gas mileage as the d series
4. D series are more prone to damages when boosted. Ie. Rods
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHC4life 96 »</TD></TR><TR><TD CLASS="quote">
.</TD></TR></TABLE>
not soo much.
have a nice ****** day
.</TD></TR></TABLE>
not soo much.
Unceasing Measure
You're not so good at putting together a case study, kid. Maybe you should take some anylitical science courses and come back to us when you know how to make a point through proper research and corroborated examples.
Simple fact: D-series motors are cheaper than crack ******, can put out a safe 200whp with less than $1500 invested and will run forever with proper maintenence. Your average B18C1 swap costs $2800 said and done and puts you solidly into the mid-to-high 14's on street tires. The "big three" might put you into the low-14's if you can drive. A turbo D16 VTEC at 200whp in the same car will put you squarely in the high-13's if you can drive it and it won't cost anywhere near $2800.
You're just failing to deal with valvecover shock.
and say a prayer for any children that might end up coming from your bloodline in the future.
