y8 headgasket
y8 headgasket
just wanted to know....if i were to put a y8 headgasket on my z6....would it make any diff. and if it is possible what all would i need to do... thanks
Re: y8 headgasket (slomofo)
Slomofo there are diffrent thickness gaskets, yes they both may be three layer but diff in thickness. For example they may come in .027 or .036 or .037 yes all three layer but diferent thikness.
GDD Member
Re: y8 headgasket (ethug4life)
Thank you for making me look like a jackass.
Still, I know what this guy is getting at, the Z6 stock CR is 9.2 and the Y8 CR is 9.6, I don't think he is going to achieve his goal of raising his Compression Ratio from a stock head gasket.
You can use any 88-00 sohc headgasket, vtec or not, any will work. Ive used a 88 paper head gasket on my z6 once...she took 15psi of boost! I have a y8 head gasket on my ZC sohc block (88-91 pm6) with z6 head.
liam
thanks for all your replies....and liam that was the point i was going for thanks...if i wanted a higher c/r i would buy a y8 head...or for that matter zc pistons...but the point i was trying to get across was price diff...thanks for your input though slomofo...somone once told me i could use a y8 gasket but i didnt know if it was compatible...thanks guys
stkinge
07-14-2009 04:56 PM
IVAN93EG
05-14-2006 11:23 PM
