Y8 block and a z6 head swap. tried searching please help. urgent.
i have a D16y8 non-vtec automatic. and i want to put a D16z6 vtec manual head on this. My question is:
1) will this combo work
2) can I use the ECU and harness from the z6 on the y8 block with no problems?
3)am I going to run into any problems with the automatic block being put into a standard transmission?
PLease let me know as soon as possible because i am about to buy the y8 block and would like to know if this all will work. i did a little bit of searching but couldn't find the answers i was looking for. thanks you guys are awesome!
Re: Y8 block and a z6 head swap. tried searching please help. urgent. (Frost_1097)
okay what?? umm im pretty sure all d16y8's are vtec... and is your car an auto or a standard because <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Frost_1097 »</TD></TR><TR><TD CLASS="quote">i have a D16y8 non-vtec automatic.</TD></TR></TABLE>
and
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Frost_1097 »</TD></TR><TR><TD CLASS="quote">am I going to run into any problems with the automatic block being put into a standard transmission?
confused me.
and
confused me.
Re: Y8 block and a z6 head swap. tried searching please help. urgent. (DannisEG6)
MY car is a D16z6 vtec standard. I am buying a d16y8 block that is not vtec and an automatic. so i just need to know if I can put my D16z6 head on the D16y8 block and still have vtec? Also, if my car is manual and the block was for an automatic will it still work in my car?
First off. All D16y8's are VTEC. It just doesn't say on the valve cover. And yes, the engine will work with your setup.
Re: Y8 block and a z6 head swap. tried searching please help. urgent. (ek99)
ok, well i guess someone removed the vtec solnoid from the Y8 head because there isn't one. but the automatic block being bolted up to a standard transmission should work? do I need to have any test done( like compression or anything like that) after I put the z6 head on the y8 block?
Yes the block will work. Was the vtec solenoid removed? Is there a place to bolt it on? If not, then its a Y7 head. And yes, a compression test is a great way to find out how healthy the motor is.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek99 »</TD></TR><TR><TD CLASS="quote">First off. All D16y8's are VTEC. It just doesn't say on the valve cover. And yes, the engine will work with your setup.</TD></TR></TABLE>
X2
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Frost_1097 »</TD></TR><TR><TD CLASS="quote">ok, well i guess someone removed the vtec solnoid from the Y8 head because there isn't one. but the automatic block being bolted up to a standard transmission should work? do I need to have any test done( like compression or anything like that) after I put the z6 head on the y8 block? </TD></TR></TABLE>
Do a compression test, and this will tell if you have a "good" motor. Z6 heads are put on Y8 blocks all the time, or vice versa.
X2
Re: Y8 block and a z6 head swap. tried searching please help. urgent. (1995Civic)
if it is a y7 block, will that work with a z6 head? the block comes out of a 97 civic. thanks for all the response so far.
Well, what does it say on the block? Either way, the z6 head will fit the y7 block.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Frost_1097 »</TD></TR><TR><TD CLASS="quote">if it is a y7 block, will that work with a z6 head? the block comes out of a 97 civic. thanks for all the response so far. </TD></TR></TABLE>
Yes.
That's what we call a Mini-Me.
https://honda-tech.com/zerothread/554053
Yes.
valoskater420
01-15-2014 05:42 PM
jdmturbo1127
11-13-2007 09:26 AM
cevinklark
12-31-2005 07:32 AM
MooreBoost
12-08-2004 06:50 PM
