Y7 to Y8 MI swap gone bad Help!
Did a y7 to y8 manifold swap yesterday and what went wrong was I put the wrong hose into my manifold, and that hose was the coolant line so coolant got into my head... What should I do? Change oil?
When I fixed the line my car fired up strong but white smoke was coming out of tailpipe I let it ran and white smoke tended to disappear and took a test drive once it finish white smoking for tailpipe, white smoke was gone but when I drove home it started to make white smoke again...
Is it because coolant is being burnt? What should I do and tips maybe a change oil to remove coolant from oil?
Desperate for help!
Info:
New head gasket (blown gasket and fixed about 4montha ago)
Water pump replaced
New timing belts
Desperate for help!
Info:
Water pump replaced
New timing belts
