y7 to y8 IM and TB question
I want to do this swap and I already found a diy online and the parts for sale, what I wanna know is if I need to buy a y8 TB or can I reuse the y7 TB. I know I can reuse the y7 fuel rail and injectors. Also will this pose any problem about the emissions so as to say my car would not pass the smog test, cuz I live in cali and all its restrictions about smog, I dont think it should cuz its OEM parts but I wanna make sure 1st before spending $. Thanks in advance HT guys and gals.
Re: y7 to y8 IM and TB question
Yeah but it didnt really specify whether I could keep the y7 TB ot not, just wanted to make sure
k thanks, is that all I need from the y8 tb?
Use throttle rotor off the y8 throttle body. Install it onto your y7 throttle body. This will allow you to run the y7 3 wire IACV instead of the y8 2 wire IACV.
You want to swap the rotors because the throttle cable is obviously routed different with the y8 side mount throttle body vs the y7 down draft throttle body.
Another tip; get a y8 throttle cable too. You can get the y7 one to work but its really long and you could run into binding issues with it.
No wiring that I can think of, youre using the y7 iacv so it is plus and play. Plus you are using your stock tps and maf so it will plug right in. Maybe you were seeing how to put a y8 head on a y7 block? In that case you need to wire vtec in.
92integra_gs
05-31-2005 02:53 PM
