y7 block with z6 head ????
i have a 98 dx and was preparing for a mini me swap, i recieved a z6 head instead of a y8. I know the dizzy does not mount properly, how do i modify it so i can make it fit??? i know it has been done, but i cant find a write up on it.
i am also using a p2p ecu and y8 intake mani.
thanks
thanks
Re: y7 block with z6 head ???? (ddp685)
use a z6 dizy, cut the wires and rewire to the ek dizy plug. I ran mine like that for a long time. Had no problems what so ever. I still have the dizy if you want it. Make an offer and you can have it. let me know. 98ctr
Re: y7 block with z6 head ???? (98ctr)
if i did get a z6 dizzy, what rewiring would i have to do because of the OBD differences with the dizzy and p2p ecu.
are u sure its not possible to use the y7 distributor?
i did this setup long time ago you can use your y7 dizzy i kno all da bolt dont line up right .. but for the top bolt on the dizzy i had to drill the bolt hole a little wider so it would fit...need any more info pm ..me.
