Y1 tranny ?
Y1 tranny ?
I have a Y1 tranny on my obd0 sir motor.......The Y1 also came in optional lsd. How can i find out if mine is an lsd tranny or not? thanks
Re: Y1 tranny ? (CfS2000)
it should say LSD on the top of the transmission.... Either that or you will have to take out the axel to look into the housing to see if you see a bar across the diff.... just look on the casing next to the transmission code and then check out the transmission code... you should be able to tell....
