WTF? throttle sticking after high RPM shift
Hey all,
What would you do about this? I have a D16z6 right now and whenever I shift higher than about 3k rpm the throttle sticks a little bit when I step on the gas again. It is getting a bit annoying! Im thinking it might be a vacuum leak or maybe I should clean my TB. Your thoughts?
RYan
RYan
Re: (SicilianSpeed42)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SVOboy »</TD></TR><TR><TD CLASS="quote">Also, clean out the inside of the throttle body!</TD></TR></TABLE>
With what, like carb cleaner or something? Gonna try that for sure, thanks bro
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spoonracer84eg »</TD></TR><TR><TD CLASS="quote">Maybe spray some type of lube like wd40 on the spring on the throttle body.</TD></TR></TABLE>
I think it opens fine, but after it decelerates after a shift it sticks closed and i have to apply a bit more pressure to snap it open. Im afraid it might be a vacuum leak goddamit! gracias.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SicilianSpeed42 »</TD></TR><TR><TD CLASS="quote">High RPM = your gas pedal further down, right? Maybe your pedal is getting stuck behind the floor mat, it has happened to me before.</TD></TR></TABLE>
hmm I dont have a floormat on my drivers side, maybe the carpet. I'll check
I used fuel injection cleaner spray and rubbed my finger around where the throttle plate closed. I had some gunk built up that was making it stick. Good luck.
Re: (hondajav06)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondajav06 »</TD></TR><TR><TD CLASS="quote">ITs your AXLE TRUST ME</TD></TR></TABLE>
Are you George W Bush?
joy123
01-03-2008 10:01 AM
