WTF???!!!
WTF???!!!
not sure if i posted this up here but again, i got an eg hatch.. my car had a hard time starting a month ago, found out that a fuse shorted out. i replaced it. drove 30mi. to work then my hatch shuts off on me while drivin on the expressway. got towed, brought the hatch to the shop... then dude tells me that he changed the main "LEEEEEELAY". hahaaa! spent 400BUCKS that day!! thenn it ran greaat until last night. downshifted at high rpm?.. fuse blew again.
any of you have any ideas on what i should do? i hate bringing it to the shop, i dont trust anyone touching it. but if i HAVE to, then i will. =/
Re: WTF???!!! (VTEC_CHiCK)
i got a nice condtion main relay from junk yard for $20 bucks and check all your ground wires..3 of them. one on battery. one at tranny to chassis and one from valve cover (or ps pump bracket) to radiator support
Re: WTF???!!! (F20B EK)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by F20B EK »</TD></TR><TR><TD CLASS="quote">400 for a main relay cost is only 46.00 you got jacked , sorry to hear that.</TD></TR></TABLE>
I know!!!!! I was gettin all crazy at the shop!! He was all like... "main relay is 80 bucks... 200 for labor... " I was pissed!!! But I couldn't do crap... =/ ...... anyways! I need help.
Wow this is a weriod problem you have here. Sounds to me like some thing would be shorting out some where... But where is the question???
Edit: Like your home page, lol Were already " Friends " lmao.
Definitely sounds like a wiring issue, something is grounding out somewhere that shouldn't be.
If you've got a multimeter then get after it. It's blowing the fuse for the ECU, so sit back while I pull the schematic for that and see if there's anything else on it.
Be back in a bit.
What fuse # is it?
Be back in a bit.
What fuse # is it?
Re: WTF???!!! (Dramier)
well if dramier can get a map of that wiring for you I can check it,
or there is that guy that could charge 1,000,000,000,000,000.00 to check it for you lol
Re: WTF???!!! (CTR_B)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CTR_B »</TD></TR><TR><TD CLASS="quote">well if dramier can get a map of that wiring for you I can check it,
or there is that guy that could charge 1,000,000,000,000,000.00 to check it for you lol</TD></TR></TABLE>
If she can tell me what fuse # is blown, I can definitely give a list of things that could be causing it to check.. but without a fuse #... -shrug-
There are several fuses that go to the ECU or as Honda calls it, the PCM.
Edit: Maybe you'll see it the second time...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VTEC_CHiCK »</TD></TR><TR><TD CLASS="quote">lol i'd rather buy a million fuses. =P</TD></TR></TABLE>
Well after talking to vtec_chick I have come to this conclusion,
She has a GSR swap in her hatch with a hacked up wiring harness. Im betting that some where in the splices there is a grounding issue occuring some where.
Im still working with her to find out where exactly where the problem lies.
Ahhhh.... Yep. Pretty good bet. But still, if you know what fuse is blowing, with a diagram and some patience you can trace the wiring and find the short.
Shouldn't be too difficult, just time consuming and aggravating.
That would be Fuse #31...
Should be a 15A fuse, btw.
Runs to the PGMFI Main Relay, which should be located under your driver's side dash, to the left of the pedals on the kick panel.
Could be a short in the Main Relay itself, which is not uncommon. Trace the yellow wire with white tracer running to the main relay under the dash. From there the main relay has wires like so:
Black: ground.
Yellow with black stripe: Goes to the ECU and fuel injectors, and also to the IACV, and evap purge control solenoid.. (Somehow I doubt you have that... lol)
Green with yellow stripe: ECU again, for fuel pump control.
Yellow with green stripe: Goes directly to the fuel pump.
In addition, from the main relay you have:
Black with yellow stripe: Power supply, runs to different fuses depending on whether or not you have SRS (airbags, etc).
Blue with white stripe: Goes to fuse #18 under-dash for power and also runs to the ECU for start input, basically tells the ECU the engine is being cranked.
So...
You are looking for anything that connects to any of those wires that shouldn't.
Black: ground.
So...
Re: WTF???!!! (Powered by VTEC)
im gonna go check the relay in the morning. hope everythings where its suppose to be =/
i'll go out and get some 15's????
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Powered by VTEC »</TD></TR><TR><TD CLASS="quote">isnt ecu fuse suppose to be 15A ?</TD></TR></TABLE>
Wow! Totally over looked that.
Edit: Wait... if it was a 20 it would be harder to pop then a 15A
Something is drawing to much amperage in the car
Well I did the noob thing to do....
I used the search button, Seems to be that there are alot of people that had this problem in the past and it all ways seems to be the o2 sensor.
The wires ground out or melt and cause the shorting/popping of the fuse.
Unplug your o2 and go for a drive.. get on it again and see if the fuse pops.
Hmm my old hatch used to do that, but it was just one of the ground wires. and gay I was gonna request ya on MySpace but "doesn't accept band requests" =[[ lol
Re: WTF???!!! (JDM-ish)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM-ish »</TD></TR><TR><TD CLASS="quote">your the one that they had the "run" for yeah?? the one that moved from oahu? i was reading on forumshawaii. bump for you :D</TD></TR></TABLE>
yessir! good times.
round2 summer08!!
yessir! good times.
round2 summer08!!
