Best swap for UNDER $3,000 for EK?
Old 12-06-2009, 12:28 AM
czirr321's Avatar
Default Best swap for UNDER $3,000 for EK?
I want to do an engine swap on my car, but I dont really want to spend over $3,000 because the car itslef is barely worth that plus it's going on 14 years old now. I dont want a race car! I just want something faster than my POS D16y7. I would like to be able to beat new RSX's and Si's. What are my options? And where is a good place to buy?
Old 12-06-2009, 12:33 AM
Linked's Avatar
Default Re: Best swap for UNDER $3,000 for EK?
posted in other thread but would like others opinions
if you want to beat new K series engines, get a K engine (which is way more than 3k)
or get a B and boost it
most likely an LS/vtec and boost it
Old 12-06-2009, 12:47 AM
94_DC's Avatar
Negative.
EK's are lighter then RSX's and Si's, so you dont need as much motor.
If I were you I would find a GSR locally shouldn't be more then 1500, then grab some bolt ons. Cams, exhaust, Intake manifold and TB should be more then enough and will only cost around 2gs with self done labor.
Old 12-06-2009, 12:51 AM
thumper64's Avatar
...for around 1k you can put a turbo setup together...
Old 12-06-2009, 01:02 AM
Linked's Avatar
ive never seen a gsr for 1,500. well not a stock one at least
most of them on the marketplace are usually built and dont part out.
if he does swap, make budget for the other things like motor mounts, or swap tools if you dont have them already
Old 12-06-2009, 01:05 AM
czirr321's Avatar
The cheapest I have seen a full GSR swap is for $2,900 online. What is a good site to go to?
Old 12-06-2009, 01:09 AM
Linked's Avatar
where do you live, i was just searching the marketplace for a gsr swap
found a FULLY BUILT complete swap for 2200, and it sounds like a deal of the century,
could fit into your budget if you dont need it shipped
http://hondamarketplace.com/showthread.php?t=2691833
be weary though, this guy doesnt have much cred here and the engine could be easily stolen
Old 12-06-2009, 01:18 AM
94_DC's Avatar
He said he didn't want a race car. (Im thinking he wants something reliable, turbo is not reliable). Even though this would be the cheaper option if he wanted to beat those cars.
Old 12-06-2009, 01:21 AM
94_DC's Avatar
or you could check your local race shops, theres at least 3 here that would sell it at that price.
Old 12-06-2009, 01:42 AM
Linked's Avatar
depending on where he lives, i never went to my shops and asked, we do have RC autoworks here in chicago though
Old 12-06-2009, 01:49 AM
thumper64's Avatar
why can't turbo be reliable? A decent tune, decent quality parts.... As long as you don't beat on it constantly, it should last.
Old 12-06-2009, 02:07 AM
looseOFFboost's Avatar
Icon7 Re: Best swap for UNDER $3,000 for EK?
ls b16 trans (approx. $800)turbo and tune (approx. $1200) And spend the rest on upgrades.
I havent met anyone yet that wants to race and stop building on there car. ThE NEED FOR SPEE is addictive.
Old 12-06-2009, 03:22 AM
kulo's Avatar
gsr
Old 12-06-2009, 03:36 AM
jkalex05's Avatar
Put a jdm h22 in there. Under your budget and good power for the EK.
Old 12-06-2009, 05:20 AM
D Griff's Avatar
about how much would a full swap H22 run? a couple thousand?
Old 12-06-2009, 05:45 AM
kulo's Avatar
h22 more will require more parts to swap
gsr will be a more drop in
Old 12-06-2009, 06:09 AM
supra-n-civic's Avatar
hmotorsonline.com is by far the best honda motor importer ive come across. there reputation is stellar. they stant behind it no questions asked and i know of abou t30 motors that came from them. that ran great. and were super super clean. almost hot tank clean.
but id look into an h22a swap they can be had for around 2200 with the lsd tranny and mounts and swap axles will run you about 450-550 depending on what ones you buy. nothing like the bottom end tourque of an h22 in an ek/eg. they are so much lighter that to make a sweet car you dont need much more. and everyone will say omg its so much heavyer. its not. its about 65 lbs more than a gsr. and lets be real its not like a civic has the best front to rear balance anyways. i did an h2b swap with a type s motor and a built b16 tranny and the thing was insane. and it still handles and stoped nicly
Old 12-06-2009, 06:18 AM
JDM H2B EK's Avatar
h22 all the way
Old 12-06-2009, 06:20 AM
Hill4589's Avatar
single cam turbo > b series swap
you can make 200 whp reliably on a d16
and it costs less than a b series swap
Old 12-06-2009, 06:45 AM
boost and bass's Avatar
X2 get a d16z6 or a d15b and turbo it iv been running a turbo D15b stock internals for 2-3 years with daily abuse and around 200hp its a good setup and fits your budget easily and takes a beating
Old 12-06-2009, 06:53 AM
dumpster's Avatar
if you have to or just want to do a swap on the cheap i would say ls then with some boost your good.
Old 12-06-2009, 11:50 AM
primaryOBSESSION's Avatar
D16A6 Block, D16y8 Head.. BUILD THE **** OUT OF IT!!
Old 12-06-2009, 12:34 PM
chinochanginc's Avatar
b20 vtec... go to the junk yard and pull the swap yourself
Old 12-06-2009, 12:50 PM
SIR-EG6-BLD's Avatar
you could always buy my K20a2 for 2800 freshly built with JE pistons (hot tanked, blasted and ready to make hp). but then you are really into it deep. You'll need a trans and kpro and mounts. Just thought i'd give you something to say "F that" to. haha.
Old 12-06-2009, 01:04 PM
infinitypro12's Avatar
Check the junkyard specials.
Quick Reply: Best swap for UNDER $3,000 for EK?
