Would changing Radiator and Water Pump cause A/C to become hot...
I recently changed the Radiator and Water Pump like a day or two ago. And now the A/C is blowing hot all of sudden. I know all hoses and everything was put back to it's original spot/place. So what could be the problem for my A/C to run warm/hot? One solution I have is, could it need recharging or w.e.? Another question have any of you used those recharging kits from Wally's World or Automotive stores and do they work? TIA..
EDIT: Read carefully.. 3 questions that need answering! DixieR3dneck |
Re: Would changing Radiator and Water Pump cause A/C to become hot... (DixieRedneck)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DixieRedneck »</TD></TR><TR><TD CLASS="quote">I know all hoses and everything was put back to it's original spot/place.
EDIT: Read carefully.. 3 questions that need answering! DixieR3dneck</TD></TR></TABLE> why did you need to put them back to their original spot? did you open your ac lines? if so you need to put your system in a vacuum and recharge your ac system. |
Re: Would changing Radiator and Water Pump cause A/C to become hot... (bigxclumzy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bigxclumzy »</TD></TR><TR><TD CLASS="quote">
why did you need to put them back to their original spot? did you open your ac lines? if so you need to put your system in a vacuum and recharge your ac system.</TD></TR></TABLE> I was just saying in general. Like every hose from the radiator or w.e. was put back. So you think the A/C might need recharging? .. Have you ever used those recharing kits that you can buy from Automotive stores or has anyone use them before? |
don't use recharge kits. check if your clutch on your compressor actually engages. and then ac system is actually operational. but there might be a slight leak, and it probably needs recharging.
Question is .. did it work before?
Re: Would changing Radiator and Water Pump cause A/C to become hot... (BatuKing)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BatuKing »</TD></TR><TR><TD CLASS="quote">Question is .. did it work before?</TD></TR></TABLE>
yes |
