Would this cause a CEL
Re: (RabbittZ)
mine didn't when it cracked. runners 3 and 4 were complealy spereated from the cat on my manifold and i had no codes. maybe yours got damaged?
oh btw, don't wast your time welding that. cast iron is a bitch to weld and the welds ususaly crack soon there-after. my welds lasted 9 months at the longest. try to find a new manifold
Re: (snail)
Get a multi-meter.
Unplug the O2 from the engine wiring harness.
Measure the resistance between the two black wires. It should read between 10-30 ohms. If yours does not, you have to replace it...you can not fix the heater section of the O2 sensor, only replace the entire unit.
I just went through the same thing, but for the 2nd O2. When I measured mine, it measured >100k ohms and had 170k miles on it.
Re: (EE_Chris)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EE_Chris »</TD></TR><TR><TD CLASS="quote">Get a multi-meter.
I just went through the same thing, but for the 2nd O2. When I measured mine, it measured >100k ohms and had 170k miles on it.</TD></TR></TABLE>
Nice info....i'v got the same code gues i'll be doing what you did here real soon....dose code 41 effect performance at all???
I have the same code, I havent tested it but in the helms there is a complete step by step trouble shooting to check if its the 02 sensor or maybe a wire going to the ecu thats cut or touching a ground
Re: (jetpilot)
Im guessing my O2 is bad instead of a wire going to the ECU, and from what I hear the code 41 makes your ECU or at least my p28 run in a safemode without VTEC
Re: (jetpilot)
hah this is too funny, I had lost the green connector from the wiring harness so I am using slide on pins to the vtec ground and pressure. I had the Ground and the pressure mixed up pulls all the way to 7200 now
Re: (jetpilot)
i had my stock exhuast mani cracked all the way around.. the giant flange from the manifold was the only thing keeping it on.. my car never threw a cell... but i just recently replced my exhuast mani and i felt a loss in torque.. when it was cracked my car would always give off a loud garggling sound when it was warming up... good side is that my car is fixed... bad side is i miss the power, even though it wasn't much but i could really feel the difference
fredtoast
05-09-2003 05:41 PM
FLIPboi
09-24-2002 07:34 PM
Qwikrex
08-01-2002 05:50 PM
