would ajustable fuel pressure regulator fix my tooo rich civic
Hey, well i've been getting some notes from other members that an ajustable fuel pressure regulator would be me answer to my problem with my 2000 civic EX, can anyone back this up or give me some info about it (maybe even how to install it)..
I'm no expert but I don't think it will. May be your FPR is bad and a new one isall you need.
I have a 92 Si Civic our FPR sets on the end of our fuel rail
On an OEM set up the FPR is usally on the front top side of the fuel rail. There are easy to change. Not sure where your is. What engine do you have.
If your running rich and the tune is correct then yes it could be the FPR.
I don't know enough about your setup or problems.
Re: would ajustable fuel pressure regulator fix my tooo rich civic (si_motor_spt)
Fix the problem that's causing you to run rich.
An adjustable fpr is no good for tuning because the fuel demand is not linear. An adjustable fpr is a bandaid for people running at the upper limit of their fuel pump and/or injectors.
Re: would ajustable fuel pressure regulator fix my tooo rich civic (suspendedHatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by suspendedHatch »</TD></TR><TR><TD CLASS="quote">Fix the problem that's causing you to run rich.
An adjustable fpr is no good for tuning because the fuel demand is not linear. An adjustable fpr is a bandaid for people running at the upper limit of their fuel pump and/or injectors.</TD></TR></TABLE>
Exactly
Exactly
Re: (1992Si)
Thats a great write up, awesome pics too, how fast does that motor run? oh, and mines is a d16y8, my FPR is located to the left on the fuel rail, wit 2 bolts going in to them.
Re: (si_motor_spt)
in my cousins car his CE light was on due to runnih to lean. put a fpr that was laying around in and adjusted it and the engine light went away and runs good.
prodragEG
Northwest (Sales)
09-19-2008 12:50 PM
Hatch'd
09-14-2005 09:00 PM
