Would an 99-00 Si exhaust tip fit on the exhaust of my civic???
Old 10-01-2002, 11:19 PM
Amuse9's Avatar
Default Would an 99-00 Si exhaust tip fit on the exhaust of my civic???
Hi, will a 99-00 civic Si exhaust tip fit on a 97 civic sedan's exhaust??
Are all the exhausts the same for all EK civics here, so basically would the Si exhaust tip fit onto my stock exhaust?
like in this picture, a civic EX put on an Si exhaust tip:
Thanks for any help
Old 10-01-2002, 11:48 PM
New User
Mr. Choi's Avatar
Default Re: Would an 99-00 Si exhaust tip fit on the exhaust of my civic??? (EK Vi-RS)
i think it might, but dont quote me on it.
Old 10-01-2002, 11:52 PM
Zero2Sixty's Avatar
Default Re: Would an 99-00 Si exhaust tip fit on the exhaust of my civic??? (Chois i-VTEC)
the tip will.
Old 10-01-2002, 11:54 PM
New User
BrandonClaps's Avatar
Default Re: Would an 99-00 Si exhaust tip fit on the exhaust of my civic??? (Zero2Sixty)
all it is is a chrome tip with a bolt that holds it, it will fit..
Old 10-02-2002, 12:07 AM
Amuse9's Avatar
Default Re: Would an 99-00 Si exhaust tip fit on the exhaust of my civic??? (BrandonClaps)
but I heard that the Si muffler is less restrictive than the lesser Civic coupes and the exhaust pipe is slightly wider, so therefore the bolt will need to go in more...
hmm I hope it works....has anybody tried this before?
Old 10-02-2002, 01:16 AM
stockegsix's Avatar
why not just get a whole 99-00 si axle back muffler, they flow better and has bigger piping, i think it'll just bolt on
Old 10-02-2002, 01:29 AM
INVALID's Avatar
Location: Why so you can pretend like youre interested, FL/OK
Default Re: Would an 99-00 Si exhaust tip fit on the exhaust of my civic??? (zzZZzzleeperCX)
Not sure about the SI exhaust tip, but the tip off a GSR will bolt up, should present the same look took. HTH
Old 10-02-2002, 05:05 AM
sohc_boy's Avatar
just get a used si exhaust it will bolt up.
Old 10-02-2002, 05:36 AM
New User
Ceeveek's Avatar
Default Re: Would an 99-00 Si exhaust tip fit on the exhaust of my civic??? (sohc_boy)
it'll work
Old 10-02-2002, 09:30 AM
Amuse9's Avatar
Default Re: Would an 99-00 Si exhaust tip fit on the exhaust of my civic??? (Ceeveek)
hmm, I'll try buying a tip and put it on..
Old 10-02-2002, 09:40 AM
kidkombo's Avatar
Location: just when you thought you were different, WA, NWforLIFE
97 civic sedan's
did you read it carefully,its a 97 CIVIC SEDAN why are you saying a coupe exhaust will fit, the sedan cat back is, i believe longer by a little bit...and yes the tip will bolt on the edge of the stock 97 exhaust.
but u never know, correct me if im wrong
Gsrsi
02-07-2012 06:46 AM
B20PWRD
01-05-2008 01:14 AM
Danethomp
06-29-2006 05:34 AM
Amuse9
11-29-2002 11:54 AM
tinkfist
11-19-2002 09:20 AM
Quick Reply: Would an 99-00 Si exhaust tip fit on the exhaust of my civic???
