wont stay running
wont stay running
I have a 97 civic 1.6l. The car starts up, but once it reaches idle rpm , it dies. I've noticed that having any electronics on while running makes it stall as well. I'm lost and I need this fixed quick. Any help would be appreciated
Re: wont stay running
Thanks guys, I checked the fluids too and noticed that the oil was bone dry and my coolant fan won't run ( just bought the car). I filled it up and its not having the problem anymore, but what it's the easiest way to diagnose the fan. Thanks again.
Cel is on, and I unplugged the IACV, it sits around 1250. I'm waiting for a code reader to get the code. Just for laughs I plugged the IACV back in and the car died
I never narc'd on nobody!
14 - IACV. Make sure it's plugged in. If it is, clean it. If it's plugged in, unplug it - does the car still die when it reaches operating temperature?
67 - Catalytic Converter. Do you have one? Do you have a secondary O2 sensor?
72/73/74 - Random misfire cyl's 2, 3, and 4. When was your last full tune-up? Check your ignition timing.
When I unplugged the IACV and the car reached temp it didn't die, it sat at about 1250 rpm. As for the tune up, that's happening some time this week as well as a new exhaust. The car has 225000 on it so I was expecting some issues
Ok, so I replaced all the plugs and wires, cap and rotor, cleaned the iacv, and rest the ecu. I'm still having the same problem though. Hard to start, then when it hits idle just turning the wheel cuts off the engine. Any other ideas?
Since I reset the ecu no lights have come back on, and it has 225000 on it. I still have to check the timing, and a compression test is next as well.
I have a cold air intake, the sensor that's in it, maf? I pulled it out and the tip of it is melted, car smells like it's burning way too much gas, like it's not getting enough air
