Won't start
Won't start
Please Help!
I have a 94 del sol SI it's the d16z6 motor and it won't start....The fuel pump whines so I know it's getting power and when I turn the key it doen't turn over it just clicks. It's not the battery, starter or soleniod (I've replaced or check all of them). So I'm kinda of stuck. There are no blown fuses also. So does anyone know which relay of switch it could be? Thanks for your help!
Re: Won't start (IVI)
I checked the battery by putting it into my brothers 92 civic and it started right up. I have replaced the start and soleniod with brand new parts. So I'm kinda stuck right now...my car has been dead for about a month and it's killing me....
Re: Won't start (DeadSol)
clean the contacts ? a click sound is either a bad starter or not enough power (bad battery).
if all is well try jumping the starter from the starter itself.
When I do that it makes a grinding noise but does not turn over and I forgot to mention it's a 5 speed and it will push off and run like a dream....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DeadSol »</TD></TR><TR><TD CLASS="quote">When I do that it makes a grinding noise but does not turn over and I forgot to mention it's a 5 speed and it will push off and run like a dream....</TD></TR></TABLE>
make sure you installed the right starter. grinding indicates its not seated properly. if your car starts by push starting it, that eliminates most of the problems. your either not getting power, or your starter is messed up.
