Wont crank!!!
Wont crank!!!
I did a JDM D15b swap in my EG and i replaced all the harnesses and the car wont crank over. Checked main relay and fuel is getting to the fuel rail. It makes a clicking sound in the fuse box under the hood when trying to start. Air, radio, cluster, etc. works. It throws a 10 and a 22 the 10 is intake temp. and the 22 is vtec but its not wired in yet. Any suggestions. Thanks
Re: Wont crank!!! (ckyfan87)
You'll get codes if you dont have those systems wired in, so thats more then likely why your getting those. Check your connections for the starter. Take a test wire and jump it to the starter solinoide wire TEMPORALY to see if it cranks that will give you an idea of the proplem but before that use a test light to see if your even getting power there. Could be a bad starter.
Re: Wont crank!!! (komat)
Checked all wiring it all connects and tried to jump battery but no luck. When i try to start it the air stops flowing and the cd player cuts off while on START.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ckyfan87 »</TD></TR><TR><TD CLASS="quote">Checked all wiring it all connects and tried to jump battery but no luck. When i try to start it the air stops flowing and the cd player cuts off while on START.</TD></TR></TABLE>
thats normal
take the starter out and take it to a auto part store to test to see if it works
thats normal
My friend helping me said it seems like a wiring problem in between the ecu and the fuse box. Do you think this is the issue.
Re: Wont crank!!! (omega02379)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by omega02379 »</TD></TR><TR><TD CLASS="quote">Why would you do that swap? I'm actually curious. Never heard of this.</TD></TR></TABLE>
I wanted something that no one around here has. I am not worried about having the fastest car. The swap actually is rather nice. Plus i bought the EG as a shell with no engine. D15B vtec motor was cheapest.
odmoht
06-06-2013 04:32 PM
boostedNOTHARDLY
11-10-2007 05:11 AM
