Changed spark plug wires and now car WONT START! - B16 Eg
Old 10-29-2010, 11:35 AM
REDEM1FTW's Avatar
Default Changed spark plug wires and now car WONT START! - B16 Eg
HELP!! I just bought a set of nology spark plug wires and installed them on my car. When I went to turn on my car it wont start, it turns over but wont crank. I put my old wires on and tried again and it does the same thing. Im getting spark and fuel pressure is good. I even swapped distributors and checked all fuses. Is there something im missing? Any advice is welcome.
- Josh
Old 10-29-2010, 11:37 AM
teggi's Avatar
Default Re: Changed spark plug wires and now car WONT START! - B16 Eg
is the firing order correct on the distributor and engine?
Old 10-29-2010, 11:49 AM
REDEM1FTW's Avatar
Yessir firing order is correct
REDEM1FTW's Avatar
im thinking main relay at this poiny
Old 10-29-2010, 12:09 PM
D50boy's Avatar
Only thing the motor needs to start is fuel, air, and spark (at the right time). If you have that, it should fire up. If you have correct timing (which i'd tripple check) spark and fuel pressure, maybe the injectors aren't opening?
Old 10-29-2010, 12:14 PM
REDEM1FTW's Avatar
Timing is spot on and fuel pressure is good. I just had my dad check the spark and he said that the "spark looks weak"?
Old 10-29-2010, 12:19 PM
D50boy's Avatar
Having fuel pressure does not always mean that the injectors are firing.
Old 10-29-2010, 12:34 PM
REDEM1FTW's Avatar
How should I check that?
I just tried cranking my car amd it backfired really loud scared the **** out of me
Old 10-29-2010, 12:47 PM
royce93EG's Avatar
i would change the rotor in the distrubitor, i had this same problem.. when you switched your spark plug wires did you take the negative off the battery? if not thats the problem. let me know how it works out.
Old 10-29-2010, 01:04 PM
REDEM1FTW's Avatar
no i Didnt disconnect the negative cable
Old 10-29-2010, 01:05 PM
300whpej's Avatar
really? ive never had this problem, and i went through a set of autozone wires almost monthly.
Old 10-29-2010, 01:09 PM
D50boy's Avatar
http://rywire.com/store/faqdesk_info...3af2fbf9d43345
You're super sure? 1,3,4,2
You can check the injectors with a multimeter to see if they get signal to them.
Old 10-29-2010, 01:18 PM
REDEM1FTW's Avatar
Originally Posted by D50boy
Lmfao I feel like a dumbass I have the distributor order right but on the notor I have the order from distributor-> cam gears as 1-2-3-4. I should have paid more attention when I took the wires off, my dad asked me.the same thing and I swore up and down it was right. Im at work now so when I get off ill swap them but im positive I f'd up the order. Thanks so much for the help everyone makes noob mjstakes every now and then lmfao
- Josh
Old 10-29-2010, 01:20 PM
D50boy's Avatar
I win!
Yea, we've all been there LOL
Old 10-29-2010, 01:24 PM
SeanK325's Avatar
- Josh
just don't tell you're dad. he'll never trust you again. haha..
Old 10-29-2010, 02:21 PM
REDEM1FTW's Avatar
im just gonna tell him it fixed itself hahaha
Old 10-29-2010, 05:09 PM
SeanK325's Avatar
Old 10-30-2010, 05:05 PM
Charisma's Avatar
HAHA that's awesome.
Old 11-06-2010, 06:08 AM
h22preludevtecx's Avatar
Spark plug wires man they'll get you every time
Boosted96gsr
01-09-2012 08:04 PM
si_motor_spt
09-02-2007 06:57 PM
MATiC
01-27-2007 08:28 AM
dumpeDc2
12-30-2004 09:25 PM
Master23
08-01-2004 08:16 PM
Quick Reply: Changed spark plug wires and now car WONT START! - B16 Eg
