Wiring help needed!
Wiring help needed!
I have my motor in my car, and it can run, but i have ran into a few unexpected wiring issues! This is the setup, jdm b16 bottom in a 94 del sol vtec. When i got the car, it was stripped (stolen recovery) so it had no wiring harness in it, I had a 92 dx harness that i used, and was going to add wires where necessary! Where i am hung up on is the map sensor? Where is the plug? and if it is the one i am thinking of, it doesn't fit right? What all do i need to do to make the dx harness work?
Re: (JUMPTHELIGHT)
Denero is a issue! Plus the only place around here that has harnesses available wants like 225.00 for a b series harness! And i could get away with a p28 harness, but they want like 125.00 for those, and i'm like f-that! I will add the necessary wires!
Re: (mattssi)
matt, i coudn't tell you where it is without looking but... look for 2 identical plugs near eachother, one is map other is tps. you might need to extend them. next time, labal all the plugs before pulling it off the motor!
Re: (ndogg)
This harness came off a dx? There are the two plugs, but one is differn't?? I know wiring, But i thought that the map's on 5g hondas all pluged up the same, this one is differn't for some reason! Everything else is where it is supposed to be (excluding vtec wires)
