Wiring Harness on my JDM B16a Gen2 OBD1? Which one?
OK i've searched for this, but didn't get a clear picture of what i'll need.
I've heard i can use my stock D16z6 wiring harness and wire it up to the knock sensors, ECU, etc. Also heard there is no such thing as USDM B16a2 with a OBD1 harness.
It's going into my 93 civic ex 4dr w/ d16z6. swapping in jdm b16a gen2.
I'm not good with these electronic parts. Any ideas on which wiring harness i'll need?
Re: Wiring Harness on my JDM B16a Gen2 OBD1? Which one? (handa)
Try this. I used it when I did my swap.http://tech.hybridgarage.com/tech/index.html
Re: Wiring Harness on my JDM B16a Gen2 OBD1? Which one? (zer0_2_6ixty)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zer0_2_6ixty »</TD></TR><TR><TD CLASS="quote">use your z6 harness </TD></TR></TABLE>
Will I need to custom cut and wire some stuff? If then, what exactly?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by handa »</TD></TR><TR><TD CLASS="quote">
Will I need to custom cut and wire some stuff? If then, what exactly?</TD></TR></TABLE>
did you not look at the link I gave you above?
5G Wiring Information
B16A2 in EG Civic
There are 6 lines to check on.
Engine Side ECU Side
Desciption Wire Color Pin/Connection
VTEC Solenoid Yellow/Green A4
VTEC Oil Pressure Sensor Blue (passenger side harness) D6
VTEC Ground Black chassis ground
Knock Sensor Red/Blue D3
Evap Purge Power Yellow/Black 12V power (hot in ON or START)
Evap Purge Solenoid Red A20
B16A2 in EG Civic
Risky Business
Yes. You will use the stock Z6 harness, and run these 6 wires
http://www.hybridgarage.com/tech/5gtech/index.html
You will need ECU pins as well as wire and some solder
Re: Wiring Harness on my JDM B16a Gen2 OBD1? Which one? (BauleyCivic)
Us the stock harness form the d16z6. You don't have to cut or extend any wires. all you have to do is cut the electrical tape on wire harness cover and pull the wires to where you need them to go. Then retape the harness. Then the only wire that you have to run is the knock sensor wire. Its that simply and yes it works i did it when i did my b16 in to my eg civic
<U>If you have the D16z6 harness you don't need to check or run any new wires there all in the right place. Besides the knock sensor wire!!</U>
Modified by jlh81 at 12:05 PM 5/31/2004
SlaMMedB16
03-26-2008 07:31 PM
white4doorsi
09-19-2005 11:25 PM
2camsaam
09-12-2003 07:43 AM
SOHCEK-Turbo
08-12-2003 01:41 PM
24hourflipness
04-26-2003 10:37 AM
