Wiring Gurus Only Please
HI
I installed an integra dash into my 93 Civic Dx, Everything worked fine( I borrowed a friends to make sure wiring was ok) and then now I finally buy a gauge cluster and it doesn't work? Its not the gauge caluster ( I tested it in a friends car) Fuse's look good and I double checked my wiring. The only light that does work is the battery light? Would a bad alternaotr cuase the cluster lights not to work?
Heres what does work:
Dimmer
Lights
turn signals
highbeams
What doesn't work:
CEL
TAch
Speedo
Clock(I have to push on the black cover for it to turn on)
All the warning lght except for the battery lght
Please does anyone know which is the main power that powers the dash? I'm thinking it might be the fuse box since power goes into it, but does n't come out?
ANy help would be great
Heres some pics
Only light that works on cluster
Under dash wiring
Dimmer
Lights
turn signals
highbeams
What doesn't work:
CEL
TAch
Speedo
Heres some pics
Under dash wiring
Re: Wiring Gurus Only Please (nickwilmot)
your supposed to use the civic dash harness and then splice in the integra plugs for the cluster, clock, hazzard, defroster. if you use the integra dash harness and plug it into the fuse box almost nothing is going to work unless yo repinn the integra dash harness.
Re: Wiring Gurus Only Please (nextelbuddy)
The integra harness does work, just got to rewire on wire for he turn signals to work
Everything worked for a whle...I just need to know where the main power or a relay that controls it is at?
ok wow it must work great then. as apparent in your picture of your cluster. io have a 2001 teg dash in my car and the teg dash wiring does plug up but does not power up everything cuz of the wiring differences. but since it works great then i guess you dont need any help
well the dash and wiring is from a 94 integra but the cluster came from a 98 integra.
2 of the plugs, plugged right up. the gray one is the one that has to be used from a civic harness.
But you tired using the integra harness and it didn't work? Hmmm.... were you getting the same problems as me?
theres ons of your problems there. the cluster wiring changed slightly on the newer clusters. you are giong to have to repin the cluster plugs. thebest thing you can do now is get a wiring diagram of the 94 gsr cluster and one for the 98 cluster compare the locations of the wires on both and then switch accordingly.
Really? What year did it change? Like 94-95 are the same and the 96-01 are the same?
Thanks for the input, didn't know it changed. But the 98 cluster wll work on a 94 integra,right? Because at first I thought it was the cluster and tried it on my firends 94 integra and it worked except he had a abs light on, when he has a RS?
Re: (nickwilmot)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nickwilmot »</TD></TR><TR><TD CLASS="quote"> Woooo Hoooooooo
Got it working
Thanks to those members that helped me out. </TD></TR></TABLE>
got the cluster working after rewiring the pins.. now get the kinks out or get your car serviced, u got a CEL, ABS, and SRS light on.. NOT GOOD AT ALL!
Got it working
Re: (Hybrid95CivicEX)
Sall good. The CEL is gone now, I unplugged the TPS sensor to make sure it was working, I removed all the SRS system and theres no ABS I got it from a LS teg so it came with that light
aubreylorraine
01-28-2011 08:34 PM
2LGSR
10-07-2010 08:35 PM
99delsol
09-14-2006 08:47 PM
hothotpete
05-10-2005 06:50 PM
