Wire locations?
Wire locations?
just two quick ones
where and which wire is my ignition switch?
which wire on my wiring harness is the primary O2 sensor wrie.
I'm hooking up an Autometer A/F gauges on a 00 Si.
thanks
thanks
Re: Wire locations? (delsolguy)
the ignition switch wire that they refer to is any wire inside the car that has 12v when the key is turned atleast 1 click (you dont want the gauge on draining power while the car is off).
The O2 sensor wire is the bigger of the 2 white wires at your ECU. Pin location C16
Ricer!
Slurp 56.. thanks alot!
I was being a tard about the ignition and right after I posted it hit me to just wire it via the 12V outlet. Only 2 wires there
Re: Wire locations? (CivSiGuy)
Let me know if you would like me to send you a couple of pigtail fuse taps. It's a standard mini-ATC fuse with a wire coming out of the head on one side. You can then plug one into your fuse box and tap off of it for ignition voltage. $1 apiece.
Re: .. (CivSiGuy)
both my cars have the OBD2 to OBD1 jumper harness,..they both have the A/F gauge,..anyways,..when i tried to splice to the ECU even trying to splice into the jumper harness and then the regular harness,..my gauges wouldnt work,..so i had to go straight to the o2 sensor,..just a thought,..i dont know if anyone else ran into this problem or not,...and its the white wire on the o2
Re: .. (CivSiGuy)
these are the instructions I followed for a 99 Civic Si (Can)
http://www.hondaracing.ca/installs/airfuel/index.htm
Hope that helps.
Hope that helps.
Re: .. (CivSiGuy)
well I finally got around to attempting to install it and it just appears to not be getting enough of a signal. It's on the lowest lean and its a very slight color. What can cause this?
Does anyone know for sure where this wire is.. and can take a pic of it?
I have a feeling that I may be in Widebody's boat.. and I'll have to go straight to the sensor.
Thanks
[Modified by CivSiGuy, 9:43 PM 1/23/2003]
Thanks
slammedz6ef
02-15-2008 07:46 AM
allanonjj
11-07-2005 01:59 PM
