Winter Protection for Camber Kit?
Winter is coming soon for me. I have the Skunk 2 camber kit, I want to know if there is anything that I can or should do to prevent the camber kit from getting damaged from salt etc. Is there a grease that I can apply on the upper arm or rubber boot of the ball joint to prevent it from cracking or rusting? Please help.
Thanks in advance.
Thanks in advance.
Re: Winter Protection for Camber Kit? (4drRacer)
I dont really live in a climate that would need salt to keep the roads from freezing but I would guess if you can hose your parts down as much as possible.. It would help..
Re: Winter Protection for Camber Kit? (u0f)
Wish I could afford a beater right now but I'm ticht on cash so..., anyways hopefully I can pick up another car next year. Anyone else with suggestions?
Also what causes the rubber boot of the ball joint on the Skunk 2 to rip? Is it caused by heat, cold or other?
I also read somewhere here that you could apply some vasilene (sp) on the boot to prevent it from cracking, will this work?
wd40 (daily)
or
weekly hose/spray it down w/ water (enough to get all the salt off),dry, lub w/ silicone spray
vaseline will work just as well as the other things..it just prevents it from drying and cracking
or
LagunaSecaEG
11
09-03-2006 07:01 AM
