Windshield wiper help....
I know this question a a little less "tech" than most would want see on here, but I'm sure somebody knows.
My wipers and washer fluid pump have quit working. Turned them on, they went halfway then stopped. I checked the fuse under the dash, but it's fine. Is there a relay or a fuse under the hood I should check? Could the motor have gone bad? I'm not sure if the wipers and the fluid pump use the same motor or not. Maybe it's the switch? Anybody have any ideas? |
Re: Windshield wiper help.... (undertheradar)
My inter. wipers died a long time ago. I'm not sure why. Anyone know? https://honda-tech.com/forums/images/smilies/emwink.gif
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by undertheradar »</TD></TR><TR><TD CLASS="quote">I know this question a a little less "tech" than most would want see on here, but I'm sure somebody knows.
My wipers and washer fluid pump have quit working. Turned them on, they went halfway then stopped. I checked the fuse under the dash, but it's fine. Is there a relay or a fuse under the hood I should check? Could the motor have gone bad? I'm not sure if the wipers and the fluid pump use the same motor or not. Maybe it's the switch? Anybody have any ideas?</TD></TR></TABLE> If both the wipers, and the fluid jets aren't working, I'd check the combo switch. I've had a few go on me before. |
Re: Windshield wiper help.... (SkyeC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SkyeC »</TD></TR><TR><TD CLASS="quote">My inter. wipers died a long time ago. I'm not sure why. Anyone know? https://honda-tech.com/forums/images/smilies/emwink.gif</TD></TR></TABLE>
Dude....get your own thread. https://honda-tech.com/forums/images...s/emsmilep.gif https://honda-tech.com/forums/images...s/emthdown.gif <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by undertheradar »</TD></TR><TR><TD CLASS="quote">I know this question a a little less "tech" than most would want see on here, but I'm sure somebody knows. My wipers and washer fluid pump have quit working. Turned them on, they went halfway then stopped. I checked the fuse under the dash, but it's fine. Is there a relay or a fuse under the hood I should check? Could the motor have gone bad? I'm not sure if the wipers and the fluid pump use the same motor or not. Maybe it's the switch? Anybody have any ideas?</TD></TR></TABLE> That would be the actual stalk switch, right? Guess I'll head to the junkyard.... |
Because you aren't cool. Your tilt steering column probably died along with them right? |
Re: Windshield wiper help.... (BauleyCivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BauleyCivic »</TD></TR><TR><TD CLASS="quote">Because you aren't cool. Your tilt steering column probably died along with them right?</TD></TR></TABLE>
No. That and my sunroof still work. So do my power mirrors. https://honda-tech.com/forums/images/smilies/emwink.gif |
No. That and my sunroof still work. So do my power mirrors. https://honda-tech.com/forums/images/smilies/emwink.gif</TD></TR></TABLE> Must be nice...my sunroof doesnt work https://honda-tech.com/forums/images/smilies/emsad.gif |
Re: Windshield wiper help.... (Dimi)
Oh yes, it is. Bronze tinted sliding goodness.
God Damned threadjackers! There's a special place reserved in hell for you guys. https://honda-tech.com/forums/images...s/emsmilep.gif
Get that combo switch checked out and get back to us.
Maybe it'll fix my problem, too. |
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dimi »</TD></TR><TR><TD CLASS="quote">
Must be nice to HAVE a sunroof. https://honda-tech.com/forums/images/smilies/emsad.gif </TD></TR></TABLE> I don't have one...thats why it doesn't work y0. |
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BauleyCivic »</TD></TR><TR><TD CLASS="quote">I don't have one...thats why it doesn't work y0.</TD></TR></TABLE>
targa top https://honda-tech.com/forums/images...s/emsmilep.gif |
That would be the actual stalk switch, right? Guess I'll head to the junkyard....</TD></TR></TABLE> Yeah, to get back OT, it is. They're easy to switch out at the column, and have a tendancy to die after a few years. |
