Window Crank Sticks on Hatch. How to make it roll up smooth?
I have a 94 Civic CX Hatch. My drivers side window cranks has been getting stuck lately. It happens mostly when rolling up the window. I roll it a half turn then i have to force it. Its starting to bug me. How do I fix it? grease or lube, if so where? Has this happend to anyone before? Any info is greatly appreciated. Thanks
Re: Window Crank Sticks on Hatch. How to make it roll up smooth? (94_HATCH)
Silicone lube. Works wonders. Spray it down in all of the tracks (both front and back) generously. I can almost 100% guarantee it'll fix it.
Re: Window Crank Sticks on Hatch. How to make it roll up smooth? (Ricey McRicerton)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ricey McRicerton »</TD></TR><TR><TD CLASS="quote">Silicone lube. Works wonders. Spray it down in all of the tracks (both front and back) generously. I can almost 100% guarantee it'll fix it. </TD></TR></TABLE>
Do you need todo anything with the crank itself?? Thanks for the info
I didn't. Went to my local Advance Auto grabbed a bottle of silicone lube (in the spraycan with the little straw for a nozzle). Went out to the car..sprayed the lube in both tracks with the window up (both inside and outside). Rolled the window up and down a couple times. Shot some more silicone lube down in the tracks while the window was down and it has worked perfectly for close to 6 months.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ricey McRicerton »</TD></TR><TR><TD CLASS="quote">I didn't. Went to my local Advance Auto grabbed a bottle of silicone lube (in the spraycan with the little straw for a nozzle). Went out to the car..sprayed the lube in both tracks with the window up (both inside and outside). Rolled the window up and down a couple times. Shot some more silicone lube down in the tracks while the window was down and it has worked perfectly for close to 6 months. </TD></TR></TABLE>
Thanks a lot man. I will try out tonight after work
Re: (BeerBaron105)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BeerBaron105 »</TD></TR><TR><TD CLASS="quote">mine started getting rough to roll up then one day it popped off the track so get that lubed up asap!</TD></TR></TABLE>
Thanks
Thanks
Morasso
09-10-2009 05:31 AM
i_am_a_black_man
08-13-2008 12:43 PM
