Wilwood Front Big Brake kit on 15" Rota Slipstreams
Old 06-01-2002, 04:30 AM
VWkila's Avatar
Default Wilwood Front Big Brake kit on 15" Rota Slipstreams
Anybody with this setup? Would this fit and any pics?
I have '92 HB. Would I have to swap a '94+ knuckles?
[Modified by VWkila, 1:35 PM 6/1/2002]
Old 06-01-2002, 09:53 AM
TodaSi's Avatar
Default Re: Wilwood Front Big Brake kit on 15" Rota Slipstreams (VWkila)
I have a 92 CX and bought the Wilwood kit from Summit and it did not even come close to fitting behind 15" rims.
I ended up buying the Fastbrakes kit with 11" two piece rotor and Wilwood Dynalite caliper and it fits awesome behind my 15" Volk CE28n rims and my Rota 15" Circuit 8 rims. I'm using stock CX knuckles. Not sure on the Slipstreams but at least now you have a little more information.
HTH
Old 06-02-2002, 05:40 AM
VWkila's Avatar
Default Re: Wilwood Front Big Brake kit on 15" Rota Slipstreams (TodaSi)
Thanks for the info!
I tried the template that was provided by wilwood.com and you're right. It doesn't come close. I'd say I need about 1/2" more to fit.
Rotors in the fastbrake kit redrilled ones?
P.S.: Where in Michigan are you?
[Modified by VWkila, 2:41 PM 6/2/2002]
Old 06-02-2002, 05:43 AM
spoon_ek9's Avatar
yea, for 15" rim, u get to call fastbrake. they have 2 choice for the 4 piston kit, 11 or 11.75" they both can clear my 15" K1(38offset).
Old 06-02-2002, 07:00 AM
Trey's Avatar
The 11" rotors in the FastBrakes kit are 4x100 11" VW corrodo rotors. No redrilling. The center bore is bigger so a hub centric ring is also shipped for each side.
I like mine!!!
Old 06-02-2002, 07:15 AM
memphiss13's Avatar
Default Re: Wilwood Front Big Brake kit on 15" Rota Slipstreams (Trey)
how much did your setups run?
Old 06-02-2002, 07:35 AM
Trey's Avatar
Default Re: Wilwood Front Big Brake kit on 15" Rota Slipstreams (rookie2nr)
http://www.fastbrakes.com
Old 06-02-2002, 09:39 AM
VWkila's Avatar
The caliper mounting brackets that come with the Fastbreake kit, is that original Wilwood made or Fastbrake made?
One more. The original Wilwood Front Big Brake kit comes with 12.19" rotors. So I'd think that Billet Dynalite caliper in the kit was designed for that 12.19" rotors. Is it safe to use smaller 11" VW rotors?
I can buy Wilwood kit @ Summit Racing for $606.00 compare to Fastbrake for $699.95
[Modified by VWkila, 6:46 PM 6/2/2002]
Old 06-02-2002, 10:23 AM
pagong's Avatar
i like mine too! I have the 11" kit w/ dynalite 4 piston calipers. You can always get slotted/drilled rotors if you want to!
not the best pic but here you go anyways
Old 06-02-2002, 11:02 AM
TodaSi's Avatar
Don't mix and match, I know I tried it, doesn't work. Ended up having Brian (Fastbrakes) overnight me some parts. The spacing on the mounting brackets will be wrong. You can purchase either kit, but the Fastbrakes kit will work with 15" rims, the Summit kit won't. Plus the Summit kit uses crossdrilled/slotted rotors which you don't need. Blanks or slots would be best.
The Fastbrakes mounts are made by Fastbrakes, very nice pieces.
Old 06-02-2002, 11:44 AM
Greg L's Avatar
The kit on summit is for cars with stock 10.25" discs, im pretty sure that my 2000 DX has smaller ones, but would it werk, or do i have to get the other wilwood kit?
Old 06-02-2002, 12:41 PM
teg92's Avatar
Default Re: Wilwood Front Big Brake kit on 15" Rota Slipstreams (pagong)
Uh hello OLD rotors!!! ???
[Modified by teg92, 4:41 PM 6/2/2002]
Old 06-02-2002, 01:07 PM
TodaSi's Avatar
Default Re: Wilwood Front Big Brake kit on 15" Rota Slipstreams (WannaBFast)
No, you have to get the kit for your car and stock disc size. That's why they have 2 kits.
Old 06-02-2002, 01:49 PM
Mr.Sha007's Avatar
did you park your car in a lake? lol. jk.
whats the site for willwood? i was concidering stoptec or move-it brakes, but i figured you that mine will do fine, im just upgrading the brake booster to a bigger one and putting powerslot rotors. http://www.powerslot.com.
Old 06-02-2002, 02:41 PM
VWkila's Avatar
Default Re: Wilwood Front Big Brake kit on 15" Rota Slipstreams (Mr.Sha007)
http://www.wilwood.com/
Old 01-23-2004, 02:44 AM
94SiHatch's Avatar
The wilwood kit wouldnt have a problem on 16" Grid's would it?
Old 01-26-2004, 03:50 PM
H22A EG6's Avatar
Default Re: Wilwood Front Big Brake kit on 15" Rota Slipstreams (94SiHatch)
that teg looks good
Old 01-26-2004, 04:13 PM
-Gambit-'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94SiHatch &raquo;</TD></TR><TR><TD CLASS="quote">The wilwood kit wouldnt have a problem on 16" Grid's would it?</TD></TR></TABLE>
it depends on your wheel offset. I have a set a 16inch le37s that clear my wilwood big brake kit but my friends 16 inch gram lites didnt clear, the spoke hit the caliper
Old 01-26-2004, 05:11 PM
WrongWD's Avatar
ive heard of lots of people using die grinders on the wilwood kit to get em to fit under 15s
Old 01-27-2004, 12:31 AM
94SiHatch's Avatar
Default Re: Wilwood Front Big Brake kit on 15" Rota Slipstreams (Evil_gambit33)
I believe its a 40mm offset, but if it came right down to it a small spacer should be reliable enough to cure that problem right?
Old 01-27-2004, 04:42 AM
Apex i ITR's Avatar
Location: Toronto, Canada currently residing in ATL, GA, USA
Which kit. The fast brakes wilwood setup would work. the big brake upgrade from Summit racing with the 12.5 rotors won't work with any 15 inch wheel.
Old 01-27-2004, 09:36 AM
-Gambit-'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94SiHatch &raquo;</TD></TR><TR><TD CLASS="quote">I believe its a 40mm offset, but if it came right down to it a small spacer should be reliable enough to cure that problem right?</TD></TR></TABLE>
Yea i little quarter to half inch wheel spacer would be enough
Old 01-27-2004, 10:14 AM
Apex i ITR's Avatar
Okay I just realized someone brought this post back from the dead. 2 years old.
Jeesus
In answer to the original poster's question if its the Summit kit then it depends on the off set of the wheels.
Old 01-27-2004, 10:15 AM
Apex i ITR's Avatar
Default Re: Wilwood Front Big Brake kit on 15" Rota Slipstreams (Apex i ITR)
Actually since the grids or a knock off of the gram lights then no it most likely won't fit if the offsets are the same.
Old 01-31-2004, 01:33 PM
JDMHN8's Avatar
Default Re: (WrongWD)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WrongWD &raquo;</TD></TR><TR><TD CLASS="quote">ive heard of lots of people using die grinders on the wilwood kit to get em to fit under 15s</TD></TR></TABLE>
You can't be serious. Please post a reference if so.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Apex i ITR &raquo;</TD></TR><TR><TD CLASS="quote">Actually since the grids or a knock off of the gram lights then no it most likely won't fit if the offsets are the same.</TD></TR></TABLE>
Acutally the Grid is a copy of the TE37/LE37, so there is a slim chance it could fit. The 12.2" kit fit fine behind my 16" TE37s and C8s.
Quick Reply: Wilwood Front Big Brake kit on 15" Rota Slipstreams
