Wilwood brake upgrade?
Im gonna be pushin some big power so i want to know i can stop when i need to. I was lookin at brake kits and I came across this wilwood kit:
http://cgi.ebay.com/ws/eBayISA...=WD1V
I was wondering how much better would this kit be as opposed to the brakes i got now (OEM).
Thanks
Thanks
Re: (MichaelJComputer)
Willwood is good but its bling! If you search on here, you can find really good upgrades from other cars (preludes, tegs,..) that will meet the same performance as a willwood. Willwood is for da bling, but if your short on cash, do a search.
really? you think other honda/acura oem calipers will stop a b17a1@20psi? If they can do that just let me know which ones to looks for, i need them to fit on a 93ex coupe.
Thanks! Hopefully I can save some cash
Re: (turbotime)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbotime »</TD></TR><TR><TD CLASS="quote">really? you think other honda/acura oem calipers will stop a b17a1@20psi?</TD></TR></TABLE>
Brakes don't stop the motor, they stop the car. What kind of speeds do you expect to be hitting with this, and where?
A drag strip? Upgraded pads will be sufficient.
A road course? Upgraded pads and fluid should be enough. Maybe run some ducting and remove dust shields.
The street? You're an idiot.
yeah id be running it at top speeds on the strip of course, and id want the brakes to be strong enough to slow me down quick enough to run a road course.
I know brakes only stop the car, thats what i want to stop. What do you mean by run ducting? What fluid/pads do you suggest?
Re: (turbotime)
It REALLY depends on what you're doing. Since you've already got 4-wheel discs I don't really think you need to upgrade the size of the rotors yet.
For drag you'll be fine with a set of Axxis Ultimates (can be used on the street too).
IF you do road course stuff you'll want to get maybe some ATE SuperBlue and track-only pads (meaning you change to them when you get there), like CarboTech XP8s.
Ducting is running drier hosing (or other similar tube) through the ducts in your bumper and to the center of your rotors, it aides cooling quite a bit.
Re: (turbotime)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbotime »</TD></TR><TR><TD CLASS="quote">no wait my car doesnt have 4way disc its got some **** drums</TD></TR></TABLE>
Crap, didn't know EX Coupes had drums. You many want to look in to getting an integra rear brake upgrade then.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MichaelJComputer »</TD></TR><TR><TD CLASS="quote">
A road course? Upgraded pads and fluid should be enough. </TD></TR></TABLE>
what fluid and pads for daily/track use?
Re: (warwagon)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by warwagon »</TD></TR><TR><TD CLASS="quote">
what fluid and pads for daily/track use?</TD></TR></TABLE>
I like the ATE super blue/gold fluid and some Hawk pads. They WILL eat those rotors though.
Re: (warwagon)
If you're a beginner at the track SuperBlue and Axxis Ultimates should be fine. If you find that you're fading those pads you'll want to upgrade to some Hawks or Carbotech XP8s at which point you'll also want to have 2 sets of pads (1 track, 1 street).
Standard civ brakes aren't that great, nowhere near good enough for track unless your a steady driver. Have a look at getting some prelude calipers which have much larger pistons, possibly one of the best mods for the price you can do to your car.
Obviously tie this in with good brake fluid and braded lines also improve brake feel which is a bonus for 'on the limit' driving.
Re: (EdLeake)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EdLeake »</TD></TR><TR><TD CLASS="quote">Standard civ brakes aren't that great, nowhere near good enough for track</TD></TR></TABLE>
With pads and fluid they should be perfectly fine for the beginner and intermediate driver. I am nearing advanced and have just now reached the limitations of the civic braking system.
Re: (bbarbulo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bbarbulo »</TD></TR><TR><TD CLASS="quote">
I just got hooked up... they're nyyce</TD></TR></TABLE>
very nice indeed.
very nice indeed.
Re: (Ricey McRicerton)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ricey McRicerton »</TD></TR><TR><TD CLASS="quote">
I like the ATE super blue/gold fluid and some Hawk pads. They WILL eat those rotors though. </TD></TR></TABLE>
sweet.... it seems like any pads i have used after fresh rotors on my civs and tegs have just warped in no time!
Re: (DeuceDeuce)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DeuceDeuce »</TD></TR><TR><TD CLASS="quote">what is the smallest rim that u can fit on the wilwood brake kit?</TD></TR></TABLE>
you tell me the whole point of this exercise was to stuff the biggest brake behind the smallest wheel... so I ditched my 15 inch Helium wheel (which I miss very much ) and took a gamble. You need 13.95" clearance straight out from the hub mounting face. Measure the wheel before you buy it.
these are 16 inch rays gram lights
Re: (DeuceDeuce)
SOME 15's will work like GSR swirlies, 99-00 Si's, spoon (i believe) with wilwood/fastbrakes 11" kit..pretty sure this was asked & answered before...i remember 15" rotas = no fit search wilwood or fastbrake topics here are a couple
https://honda-tech.com/zerothread?id=149706
https://honda-tech.com/zerothread?id=95179
Re: Wilwood brake upgrade? (turbotime)
i have wilwood brakes, they stop the car alot better than the stock brakes, wilwood uses 4-piston calipers instead of the stock 2-piston, so ur gonna have better braking power. 16' inch wheel is the smallest that can fit also
