will a Z6 oil pan fit a Y8???
will a Z6 oil pan fit a Y8??? **~~PICTURES~~**
as topic says, will it fit? also if it does are the oil pan gaskets the same or different? because i bought one for a y8 but oil pan has a crack in it, so i bought a z6 and was wandering if it fits. thanks for the help!
Modified by whitesw20 at 10:13 PM 6/18/2004
Re: will a Z6 oil pan fit a Y8??? (whitesw20)
It will only fit if you use a Z6 oil pump and oil pickup. If you do this you will have no way to check your oil level on a '96 newer block.
