Will a Type R Brake Booster and Master Cylinder work in a 93 Civic Hatch?
As stated above. I am getting no pedal pressure after bleeding the brakes. Sounds like it is leaking from the booster or master cylinder.
Re: Will a Type R Brake Booster and Master Cylinder work in a 93 Civic Hatch? (SOHC4life 96)
ABS will work too but you need different lines. I got one for sale if you want
Re: Will a Type R Brake Booster and Master Cylinder work in a 93 Civic Hatch? (TurboR1391)
You would need the 2 lines that go into the MC because on ABS there bigger. Most people just get custom SS lines.
* B A N N E D *
1 Post
What do you mean Type-R? From a Civic Type-R?
A 15/16" MC from a 1991 Honda Civic EX Sedan will bolt onto your stock brake booster if that helps. You have to bench bleed the MC first. If you don't you may spend 3 quarts of brake fluid gettin all the bubbles out the lines.
dailydrivenHONDA
06-08-2009 01:16 PM
fongph
06-16-2006 06:05 PM
DRKSol
09-14-2004 09:04 AM
