Will a sir ecu work on a vti engine?
Old 09-13-2012, 08:39 AM
vtecT's Avatar
Default Will a sir ecu work on a vti engine?
I have a 98 1.6 vti honda civic coupe. Im just wondering if i pluged out the vti ecu would a sir ecu work without any problem?
Old 02-08-2016, 07:34 PM
Oh look, I can change this
deschlong's Avatar
Default Re: Will a sir ecu work on a vti engine?
Let's talk more about which motor is under the hood rather than model. Also obd2/2a etc.
Old 02-10-2016, 04:56 AM
JDM_SOHC's Avatar
If you are talking about the B16A VTI then yes it will run, but not without issues.. The parameters are a bit different such as timing, fuel maps, vtec engagement, rev limiter, etc.. But it will start and drive if that's all you need it to do.. I'd suggest just chip/tune the EDM P30 or buy one for your specific setup to match the more aggressive parameters if that's what you're after..
Old 02-10-2016, 08:27 AM
Fish Twig
tony_2018's Avatar
Details on motor and ecu, you know what we need.
99Civic hatch
10-09-2001 12:47 PM
Quick Reply: Will a sir ecu work on a vti engine?
