will my timing be off a half a tooth when doing a mini-me??
Old 08-02-2005, 09:59 PM
mike93eh
Guest
Posts: n/a
Default will my timing be off a half a tooth when doing a mini-me??
i heard that timing will be off a half a tooth retarded or advanced when doing a mini-me. is this true? is that too bad or should i just get a adj. cam gear?
Old 08-02-2005, 10:10 PM
FalkenSiR's Avatar
Default Re: will my timing be off a half a tooth when doing a mini-me?? (mike93eh)
I can't help you a lot but I can tell you that if you get the right belt, then you are ok. Because I don't know the head/block/belt combos...
Old 08-06-2005, 09:59 AM
mike93eh
Guest
Posts: n/a
great my car is not running good at all, has to be timing but i dont know what you have to do when putting a y8 head on a b7 block. jeeeez.
Old 08-06-2005, 10:18 AM
mengo_charged's Avatar
Default Re: (mike93eh)
How's it running? I just did mine last week and it's got a shitty asssss low idle right now. It doesn't feel like it picks up either, like it's choking out on something.
Old 08-06-2005, 09:28 PM
mike93eh
Guest
Posts: n/a
Default Re: (mengo_charged)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mengo_charged &raquo;</TD></TR><TR><TD CLASS="quote">How's it running? I just did mine last week and it's got a shitty asssss low idle right now. It doesn't feel like it picks up either, like it's choking out on something.</TD></TR></TABLE>
thats exactly how mine is, ive tried every possible combinationa dn it doesnt get any better.
Old 08-06-2005, 09:46 PM
Civicse's Avatar
what timing belt do u have on right now? cause i'm pretty sure u will need the y8 belt, use the belt that goes with the head
Old 08-06-2005, 09:53 PM
mike93eh
Guest
Posts: n/a
Default Re: (Civicse)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Civicse &raquo;</TD></TR><TR><TD CLASS="quote">what timing belt do u have on right now? cause i'm pretty sure u will need the y8 belt, use the belt that goes with the head</TD></TR></TABLE>
y8 belt. keep them coming guys, its gonna be a long night.
refer to this...
https://honda-tech.com/zerothread?id=1331760
Old 08-06-2005, 09:54 PM
USDMGD3!'s Avatar
yes the timing is gonna be off, just advance the cam gear 1/2 a tooth and u will be fine. not sure if that goes for all mini me conversions such as obd2 head... someone could chim in this... btw did u by anychance mill the head?
Old 08-06-2005, 10:23 PM
mike93eh
Guest
Posts: n/a
head hasnt been milled... and like i said i have tried EVERY possible combination. advanced and retarded 1 degree at a time up to +-10 degrees. and nothing!!!!!!!!
Old 08-06-2005, 11:47 PM
USDMGD3!'s Avatar
maybe it has to do with the distributor since the head ur using is OBD2 and ur using the old distributor which is OBD1? or do u have both? u might wanna look into how to convert the OBD1 wires to OBD2 if u already dont have the right distributor...
when i did my mini me (R.I.P) it didnt start up my first try. i over tighten the valves and it was hard to start it up and when it did it idled like cr@p and would die. so i loosen them up and fired right up...
btw what ecu are u running?
Old 08-07-2005, 02:04 AM
92ehatch's Avatar
Default Re: (OZ Rally)
shoudl take y8 belt
Old 08-07-2005, 08:21 AM
mike93eh
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by OZ Rally &raquo;</TD></TR><TR><TD CLASS="quote">maybe it has to do with the distributor since the head ur using is OBD2 and ur using the old distributor which is OBD1? or do u have both? u might wanna look into how to convert the OBD1 wires to OBD2 if u already dont have the right distributor...
btw what ecu are u running?</TD></TR></TABLE>
running p28. valves are good. checked them many times. its not the dizzy.
teamrpm2
19
01-28-2020 08:41 PM
chokingvictim99
Engine Management and Tuning
04-25-2011 06:13 AM
that1kid
03-16-2007 07:40 AM
Scrapin4DR
04-11-2006 06:05 PM
Quick Reply: will my timing be off a half a tooth when doing a mini-me??
