Will jdm H22a work w/ oem p28 while i send my jdm p13 out for rechipping?
Like it says boyz, its my daily driver and im sure it will take at least a week to send it and come back. kenji is gonna do the rechipping for me. but i need to know if i can use my oem p28 on my jdmh22a.
thanks again guys!
electron-eg
thanks again guys!
electron-eg
Re: Will jdm H22a work w/ oem p28 while i send my jdm p13 out for rechipping? (JDMH22HATCH)
I wouldn't be to hard on your car cause that ecu will make you run really lean possibly causing detonation.
Re: (electron-eg)
detonation from not enough fuel -- p28 sohc 1.6 ecu.... p13 - dohc 2.2 ecu... slightly different fueling needs...
be very easy on it if you want your motor to survive
Re: (B16B)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B16B »</TD></TR><TR><TD CLASS="quote">detonation from not enough fuel -- p28 sohc 1.6 ecu.... p13 - dohc 2.2 ecu... slightly different fueling needs...
be very easy on it if you want your motor to survive</TD></TR></TABLE>
indeed but remeber its not that bad, as the p28 ecu is programmed to run a 240cc injectors while the h22a uses 310-350cc injectors.
B16b... sorry bro i dont have any chips, you can find tons of them on ebay though. their only like 15 bucks +shipping. after that, just finding someone to install it.
Re: (B16B)
if the p28 is chipped it should run, but if you are using the peak and hold fuel injectors it's not gonna run perfectly.. i had to do this for a while when i was getting my p13.. i was using a chipped p28.. the vtec didn't work and lots of little things, but it worked tho.
