Will I need to compress these springs when lowering?
I've heard that you DON'T need to compress the springs depending on the car..
I have a 99 Civic, I am going to try to afford some Eibach pro-kits, but I'm not 100% sure whether I need a spring compressor tool for these with the stock shocks..
Is it possible without the tool?
In The Garage
Re: Will I need to compress these springs when lowering? (Nameless)
its possible to take them off w/o a compressor (very fatal) but, unless youre he-man (yes, i said he-man) you will need a compressor to put them on. as far as ive experienced, you only dont need a compressor when putting on coilovers.
Right you don't need to compress the springs since the mass of the car and gravity will take care of that. What you do need is something to decompress the stock springs when taking apart the assembly. Just go to a auto parts store and get one...it's safer that way. BTW my friend got something that is set up like a vice but it attaches to the coils on the spring and you loosen the bolt to slowly decompress the spring...and good news is they are cheap.
yah you do need to compress the stock springs in order to put something else on for example lowering springs or coilovers..the way that my brother taught me was to shoot it (bad idea) instead of renting out the strut compressor.. IMO it was a little bit harder since it took longer time buy it was well worth it then having two eyes to start with and finishing up the car with one eye...heehee
Re: Will I need to compress these springs when lowering? (-=[]DeLSoLaTrOn[]=-)
put it in a blanket and hit it with the gun it will come right off. Just dont stick your head right in front of it!
Re: Will I need to compress these springs when lowering? (js96ek)
*I've only used a spring compressor once, and it took forever. Now I just pop it out w/o one*
Re: Will I need to compress these springs when lowering? (Jay-C)
Yeah I'm that guy that has the spring compress/decompress tool. I normally use it just in case, but I've done it without them before. Actually, almost everytime I do them for myself I don't use them but when I have other people working with me I do for their safety.
My friends normally put the shock in a chain link fence, against the curb, blankets, or something else. The important thing is that you aren't standing right over it like a fool as you loosen the top nut.
you dont NEED a compressor. i put on all four of mine without one. its not a problem getting them on the car if its on a lift. i dont know what you are using. the hardest part is the nut at the top. it sucks.
LOL oh yeahhhhh !!!!
Anyhow, go to Autozone and rent a spring compressor for $40 and you get all your $$ back at the end when returned. You'll NEVER get the springs back together without having the compressors. ONly coilovers work that way as stated above. Been there done that, Autozone is where you need to go
You can drop the spring and strut assembly/component down from the bottom.
Its removing the top nut from the boot of the strut, thats where you may want to compress or just use the blanket and a wall method. As soon as you open up this nut the spring will go BOING !!!
So play it safe with a spring compressor or just aim for the wall and hold it down with a blanket. Either way it comes out just dont shoot your eye, its also a good way to test your reflexes.
and yeah you can rent a compressor from autozone.
Re: Will I need to compress these springs when lowering? (22lbGS-R)
I guess I am He-man
Re: Will I need to compress these springs when lowering? (Civichatch972)
I've never used a compressor... I rented one to use once probably 6 years ago, but I didn't end up using it, it's easy enough without.
peaces.
peaces.
blinger
Suspension & Brakes
01-24-2007 08:08 AM
