will GSR suspension fit on Civic CX
i just bought GSR Front arms, calipers, rotors, pads, GSR Rear trailing arms, rotors, calipers, pads, GSR Brake Lines, and GSR brake booster/master cylinder. One of my friends told me that with my stock CX steelies, it wont fit, is this guy a fool, or will i need to make some changes in order to instal the GSR suspension on my 93 Civic. thanks.
Re: will GSR suspension fit on Civic CX (Navid OG)
all that will fit except for the brake booster and M/C u will need to reflare brake lines for compatibility. if u run those gsr brakes on there u can not fit the CX steelies they are too small. u need to get 14 inch wheels or bigger. good luck
Re: will GSR suspension fit on Civic CX (EBP_SI)
Definitely not a fool (I take it you're the friend who told him), I have GSR stuff all around and couldn't fit anything less that 14". This kept me from selling wheels a couple of times, but hey I can stop better.
Yeah as the other guy said, you won't be able to use the MC and booster since its from a car with ABS. You can use an RS master cylinder or check back in one of Tom's posts because I beleive he said theres an 88-91 MC that works fine.
Re: will GSR suspension fit on Civic CX (ill phil)
i went to the junk yard and pulled the M/C off of a 92-95 civic 4 door with 4 disc brakes and it bolted up to my car. the M/C form those cars was a 7/8 and its great. i also have the 40/40 prop valve from the rs integra.
Re: (B18CBungy)
the cx gas 9.5 front rotor and drums in the rear... the tegs have 10.3" up front and 9.2" in the rear.... I upgraded my cx and it helps a whole lot... check out my ad in the classifieds.. I am selling the set ups as we speak (shameless plug)
Re: will GSR suspension fit on Civic CX (mycvc8u2)
Ok I have a Power Brake Booster from a 2000 GSR and it fits in there perfectly, Also get the Master cylinder from a 91 Civic EX it is a 15/16th units and everything fits perfectly.
spoon_concept_eg6
23
08-21-2009 11:06 PM
hatchboy93
04-06-2003 07:12 AM
