will gsr rear sway bar fit on a 92 CX?
Re: will gsr rear sway bar fit on a 92 CX? (DreamSpeed)
You'll need Civic Si / EX or Integra (except TypeR) LCA's. Easy job, just do an alignment afterwards.
Anthony "Mario" Crea
Re: will gsr rear sway bar fit on a 92 CX? (honda93)
no, the EX/Si rear LCA will not work. use 94+ integra Rear LCA's and sway bar, make sure to get all the bolts and brackets and it should be a direct bolt in, except for the D brackets some cars have the holes threaded and some do not. Honda93 is right about the front you can use the EX/Si front LCA for the gs-r front sways
Re: will gsr rear sway bar fit on a 92 CX? (stkd16z6)
I am pretty sure you can use the rear LCA from a civic EX (not a dx) sedan though. As it was the only 92-95 civic with a rear swap bar. All the other body styles didnt have one.
liam
liam
allenp
14
08-03-2006 01:46 PM
thehatchninja
11-07-2003 10:21 AM
