Will Goodridge SS brake lines for a DX fit EX brakes?
I bought some goodridge lines for my 9.5" '93 DX brakes that I have not yet installed, but have 10.3" brakes (knuckles, rotors, calipers, booster, MC, prop valve) from a '95 EX I think I'm going to put on. Question is will the lines for the DX calipers (akebono, I believe) fit the EX ones (Nissin)?
Also are the prop. valves between the EX and DX different even though they both have rear drums? If not, do the hardlines line up, or do I need to bend and re-flare?
Thanks
Thanks
Re: Will Goodridge SS brake lines for a DX fit EX brakes? (jgop_151)
Does your 10.3" set-up have the old brake lines attached? If so, do a side by side comparision.
I reused my old lines when I swapped to the 10.3 brakes. The lines came up short. I don't know if the SS would be any longer. I have a 93 dx hatch.
D Tranny Guru
fits perfect.
I have the Goodridge lines, and 9.5 and 10.3 front brakes.
Just don't lose the washers when swapping the brakes.
I'm running the small brakes again as I'm running on 155/80/13's on stock steelies for now.
Going for the sleeper look
Once I get a 12.9999999 timeslip, the bigger brakes go BACK on and the conversion to road racing setup begins.
Re: Will Goodridge SS brake lines for a DX fit EX brakes? (Mista Bone)
Sweet, thanks alot! One more question, might be dumb but I'm guessing the pads between the calipers are different and pads for the DX won't fit the EX calipers?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mista Bone »</TD></TR><TR><TD CLASS="quote"> .... I'm running on 155/80/13's on stock steelies for now.
.....</TD></TR></TABLE>
155's?!!
i thought 175's were stock? at least that's what i had before i went for the 205's
i think i've seen bicycle tires twice as thick!
-Sketch
155's?!!
-Sketch
D Tranny Guru
Re: Will Goodridge SS brake lines for a DX fit EX brakes? (Sketch_hs)
people do laugh at them, but when I bust their ***, the have no clue WTF just happen. Only paid $104 for them mounted and balanced. Makes sliding the car around corners a but hairy.
I like playing with 99-00 Si's with 16"-17" wheels. They have no clue why a SOHC just walked away.
Mr_Bojangles
05-18-2004 03:27 PM
